Extrafields
Extrafields allow to add others datas to Dolibarr standard database schema. Introduced in version 3.2, extrafields are now implemented in businesses object :
  • Thirdparties & contacts & users
  • Events
  • Customer Invoices
  • Proposal
  • Products & services
  • Member & member type
  • Orders
  • Projects & project tasks (since 3.4)
Technical implementation
Each object have his table in database to store values of extrafields.
Datatables extrafield tables models is :
llx_BaseTableNAme_extrafields
 rowid                     integer AUTO_INCREMENT PRIMARY KEY,
 tms                       timestamp,
 fk_object                 integer NOT NULL,
 import_key                varchar(14)
Display page have to include :
require_once DOL_DOCUMENT_ROOT.'/core/class/extrafields.class.php';
Load extrafield array in object :
$extrafields = new ExtraFields($db);
$extralabels=$extrafields->fetch_name_optionals_label('''ObjectClassName''');
Load extrafield into object :
''$object''->fetch($rowid);
''$object''->fetch_optionals($rowid,$extralabels);
[[Before call $object->create or $object->delete :]]
$ret = $extrafields->setOptionalsFromPost($extralabels,''$object'');
Inside edit page to display extrafields :
$reshook=$hookmanager->executeHooks('formObjectOptions',$parameters,$act,$action);    // Note that $action and $object may have been modified by hook
if (empty($reshook) && ! empty($extrafields->attribute_label))
      print ''$object''->showOptionals($extrafields,'edit');
Inside view page to display extrafields :
      print ''$object''->showOptionals($extrafields);
Inside New page to display extrafields :
