Module Hosting
Revision as of 08:15, 17 January 2013 by Eldy (talk | contribs) (Uniformize title beteen all modules)
Hosting
Numéro/ID du module 1600
Doc développeur du module Module Hosting (developer)
Module name
Editor / Editeur aternatik (www.aternatik.fr) - Project page on doliforge.org
Dolibarr min version: 3.1    Dolibarr max version: {{{maxversion}}}
Last update date / Date mise à jour fiche / Fecha última actualización 2013-01-17
Manage internet hosts and extensions with Dolibarr.
You can add a host by clicking the button labeled "Hosting" in the main menu. A link is then present in the left menu to access the form to create the host object.
Extensions
In the module hosting alone, a host does not have a lot of properties. To overcome an extension system is available to manage other types of information such as the domain name or IP address and re-use these data to perform treatments.
For the time extension is available to manage (administratively) of Internet domain names in Dolibarr. More info at dolistore.com
More info
Acquire the module: www.dolistore.com
