Module Hosting
Hosting | |
Numéro/ID du module | 1600 |
Doc développeur du module | Module Hosting (developer) |
Module name | |
Editor / Editeur | aternatik (www.aternatik.fr) - Project page on doliforge.org |
Prerequisites / Prérequis |
Dolibarr min version: 3.1 Dolibarr max version: {{{maxversion}}} |
Last update date / Date mise à jour fiche / Fecha última actualización | 2013-01-14 |
Note / Nota |
Manage internet hosts and extensions with Dolibarr.
Use it!
You can add a host by clicking the button labeled "Hosting" in the main menu. A link is then present in the left menu to access the form to create the host object.
Extensions
In the module hosting alone, a host does not have a lot of properties. To overcome an extension system is available to manage other types of information such as the domain name or IP address and re-use these data to perform treatments.
For the time extension is available to manage (administratively) of Internet domain names in Dolibarr. More info at dolistore.com
More info
Acquire the module: www.dolistore.com
