Module SkinEditor
| Module name | |
| Editor / Editeur | NLTechno (www.nltechno.com) - www.dolistore.com |
Dolibarr min version: 3.2.0 Dolibarr max version: {{{maxversion}}} |
| Last update date / Date mise à jour fiche / Fecha última actualización | 2012-12-7 |
| Note / Nota |
Allow to change the main color and font size of skin eldy. Setup can be done globaly for everybody, but each user can also personalize its color theme by himself.
Prerequisites
Use the eldy skin.
Specific setup page for module:
You can define the colors globally (for everyone) but each user can also edit himself the color.
To change globally, go into the setup page of module, fill:
- The color code to define skin main color.
If a use want to change himself, he have to click onto its login name (top-right), choose tab "skin editor", then fill:
Once setup of module is done, Dolibarr use new colors.
