Hooks system
Revision as of 13:41, 26 November 2012 by Grandoc (talk | contribs)
Hooks is a developer feature, available with Dolibarr 3.2 and more, to allow developer to add personalized code into Dolibarr core code with no need to patch Dolibarr. On the contrary to the triggers (another feature to interact with Dolibarr code) which are by definition linked to a business action, hooks can happen anywhere at anytime, they are entry points into the program.
  • Hooks work by context (ie the module, eg: "productcard" for products, "invoicecard" for invoices, etc..). It's easy to find them, just search for "initHooks(" into php files.
  • Hooks are functions that can be overloaded by your own. You decide if your code is added to standard Dolibarr code or if it replaces Dolibarr code. You can find overloadable functions by searching for "executeHooks("
Implementation
To implement a hook in your own module (so that your module can be hooked by others), you have two steps to follow.
These steps must be followed for every php script of your module where you want to implement hooks.
$hookmanager->initHooks() takes 1 parameter (an array of contexts) and activate the hooks management for this script:
- 'context' is the module's context as a string. This is simply a indicator that hooking functions can use to detect which modules they want to hook (several different modules can have the same hooks names, but a hooking function may want to hook only one specific module and not the others).
Note: you can set several contexts in the same script (for example if you want to break the functionnalities of your script into smaller parts, or if you are mixing several modules into one, for example when you do a bridge between modules or third-party application).
2- Place hooks wherever you want in your script:
$parameters=array();
- $parameters is a custom array to send more custom data to the hook (the hooking function can then process it). Place here anything you want, it can be a file, an array of strings, anything...
eg:
- $object is the object you want to pass onto the hooking function, mainly the current module's data (eg: invoice object if it is invoice module, etc..). This can be anything you want, but remember this will be the main component hooking functions will be using.
Now your module should be hookable, and you can follow the procedure below in Usage to implement a hooking function that will take advantage of your new hooks.
Note2: If your hook can't be accessed, try to DISABLE then RENABLE your module for the hooks to be taken in account by Dolibarr (may not be required).
To use a hook (add or replace a part of code), you first need to already have defined a module (see the wiki for that), and then you need to do 2 things:
1- add your module to the list of contexts you want to hook on. This means that when a context you hook will happen, your module hook code will be called. To do that, just edit your /htdocs/yourmodulename/core/modules/modYourModuleName.class.php and edit the $this->module_parts variable with something like this:
$this->module_parts = array(
'hooks' => array('hookcontext1','hookcontext2')  // Set here all hooks context managed by module
Of course change YourModuleName with your own module's name.
Note: you can find the current module's context with print('Module context: '.$object->context); (put this inside the module's php file where the hook resides and that you want to hook).
IMPORTANT: Be careful: do not forget to DISABLE then RENABLE the module in the admin panel to accept the new context, because these constants are only added to the database when enabling the module.
<?php
    /** Overloading the doActions function : replacing the parent's function with the one below
     *  @param      parameters  meta datas of the hook (context, etc...)
     *  @param      object             the object you want to process (an invoice if you are in invoice module, a propale in propale's module, etc...)
     *  @param      action             current action (if set). Generally create or edit or null
     *  @return       void
        print_r($parameters);
        echo "action: ".$action;
        print_r($object);
        if (in_array('somecontext',explode(':',$parameters['context'])))
where
  • $parameters is an array of meta-data about the datas contained by the hook (eg: the context, always accessible by $parameters['context']).
  • $object is the object that you may work on. Eg: the product if you are in the productcard context.
  • $action is the action if one is conveyed (generally "create", "edit" or "view").
How to find a complete list of all available hooks in Dolibarr's nomenclatura ? Just search for "executeHooks(" through the whole sourcecode (generally called "find in files") and you should easily find all the hooked methods calls.
This is however a small list of them (not complete): Template:ListOfHooks ...
Note: please note that this list may change in the future as hooks and contexts are added into Dolibarr, so if you really need to find a specific hooks, please search directly in the sourcecode.
To find the complete list of available modules' context in Dolibarr's nomenclatura, the procedure is similar to finding hooks. Search for "initHooks(" through the whole sourcecode (generally called "find in files") and you should find all the possible contexts.
This is however a small list of them (not complete): adherents\card.php(111): membercard
comm\card.php(72): commcard
user\card.php(93): usercard
user\list.php(72): userlist
See also
