Module Catalog
Revision as of 17:38, 9 November 2012 by Fmarcet (talk | contribs) (Created page with "Category:Complementary modules Category:Products {{TemplateDocDevEn}} {{TemplateDocUser}} = Informations = {{TemplateModuleInfo |editor=2byte.es ([http://www.2byte.es www...")
Module name
Editor / Editeur 2byte.es (www.2byte.es)
Dolibarr min version: 3.1    Dolibarr max version: {{{maxversion}}}
Last update date / Date mise à jour fiche / Fecha última actualización 2012-11-9
Generates a PDF catalog of products and services contained in Dolibarr. Allows management of catalogs by month and year.
More info(Spanish only)
Module info by official developer: www.2byte.es
Technical info and manuals: www.2byte.es
Acquire the module: www.dolistore.com
Terms of Use, Maintenance and Support: www.2byte.es
