Module Reports
Revision as of 17:02, 9 November 2012 by Fmarcet (talk | contribs) (Created page with "[Category:Complementary modules]] Category:Reports {{TemplateDocDevEn}} {{TemplateDocUser}} = Informations = {{TemplateModuleInfo |editor=2byte.es ([http://www.2byte.es www.2...")
Module name
Editor / Editeur 2byte.es (www.2byte.es)
Dolibarr min version: 3.1    Dolibarr max version: {{{maxversion}}}
Last update date / Date mise à jour fiche / Fecha última actualización 2012-11-9
Management, printing, viewing and exporting reports. The export can be done in CSV and PDF. You can request for further reports. The module allows us to manage groups of reports
More info(Spanish only)
Module info by official developer: www.2byte.es
Technical info and manuals: www.2byte.es
Acquire the module: www.dolistore.com
Terms of Use, Maintenance and Support: www.2byte.es
