Module Labels
Revision as of 15:58, 9 November 2012 by Fmarcet (talk | contribs)
Module name
Editor / Editeur 2byte.es (www.2byte.es)
Dolibarr min version: 3.1.0    Dolibarr max version: {{{maxversion}}}
Last update date / Date mise à jour fiche / Fecha última actualización 2012-11-9
Create labels printing for products in 70x36 and 70x37 format
More info(Spanish only)
Module info by official developer: www.2byte.es
Technical info and manuals: www.2byte.es
Acquire the module: www.dolistore.com
Terms of Use, Maintenance and Support: www.2byte.es
