Module CustomFields Cases
| CustomFields | |
| Numero/ID of module | 8500 |
| User doc. of module | Module_CustomFields |
| Developer doc. of module | Module_CustomFields_Dev |
// ... php code ...
function __constructor($db) {
// ... php code ...
$this->name = "crabe";
into:
// ... php code ...
// ... php code ...
$this->name = "customfields";
* \brief Show the customfields in a new page
* \param pdf PDF factory
* \param object Object invoice/propale/order/etc... (CustomFields simpler functions will automatically adapt)
* \param outputlangs Object lang for output
global $conf;
// Init and main vars
$pdf->SetY($pdf->GetY()+1);
// Printing the customfields
// Get translated label
return 1;
Alternative function (with a bit less functionalities, but more controllable):
* \brief Show the customfields in a new page (used to debug if CustomFields setup is correct)
* \param object Object invoice/propal/product/whatever...
if (empty($object->table_element) or empty($object->id)) {
$pdf->MultiCell(0,3, "Current \$object is not compatible with CustomFields, could not find table_element or id.", 0, 'L');
return 1;
include_once(DOL_DOCUMENT_ROOT.'/customfields/class/customfields.class.php');
$customfields = new CustomFields($this->db, $object->table_element);
// Fetching custom fields records
$fields = $customfields->fetch($object->id);
if (!isset($fields)) {
$pdf->MultiCell(0,3, "No custom field could be found for this object. Please check your configuration (did you create at least one customfield and set a value in the current datasheet?)", 0, 'L');
return 1;
} else {
foreach ($fields as $key=>$field) {
$translatedname = $customfields->findLabelPDF($key, $outputlangs); // label of the customfield
$value = $customfields->simpleprintFieldPDF($key, $field, $outputlangs); // value (cleaned and properly formatted) of the customfield
$pdf->MultiCell(0,3, $translatedname.': '.$value, 0, 'L'); // printing the customfield
return 1;
// Pied de page
$pdf->AliasNbPages();
// CustomFields
$pdf->AddPage();
$pagenb++;
Conditions categories
- static condition: choices are restrained on a condition that never changes (eg: only show third-parties that are suppliers, or lowercase all data on sql insertion, or check that a field is above a certain number, etc.).
- semi-dynamic condition: choices that are constrained on a static table but based on the value of another field/customfield.
- dynamic: everything is dynamic: choices are based on a subfield of a field of the current module, so that there's no material table and it's impossible to create a view (because you would need to create one view per id) (eg: show only the contacts attached to the third-party being accessed)
- timed condition: a condition that is based on time or recurrence (eg: at 5:00 AM delete old records, etc..)
Conditions solutions
Static condition
- View: create a view on the table based on the condition, and then create a custom field constrained on this view (which is just like any table), eg: only show third-parties that are suppliers:
SELECT *
FROM llx_societe
WHERE fournisseur=1;
- Check
- Trigger
- SQL Transformations
- CustomFields's overload functions
Semi-dynamic condition
- View
- Check
- Trigger
Dynamic condition
- Making your own module, which calls the CustomFields class
Timed condition
- SQL scheduled events
- Cron job
Overloading functions
1,les 2 alpes,isère 2,chamrousse,isère 3,alpe d'huez,isère 4,vars,alpes du sud 5,risoul,alpes du sud etc...
In CustomFields's admin panel, we create two custom fields: 1-secteur: returns the list of all zones - type DropdownBox: enum('- Aucun','Alpes du Sud','export','Haute-Savoie','Isère', etc...) 2-station_a: returns the list of all ski resorts - type constraint on llx_k_station
$result=$db->query($sql);
if ($result) {
$i = 0;
$myarray = array();
while ($i < $num)
$i++;
$value = $myarray;
$db->free($result);
Linking Dolibarr objects from two different modules
The key here is to use the llx_element_element: this is a standard Dolibarr table that stores all links between objects of two different modules.
Here is the structure:
rowid | fk_source | sourcetype | fk_target | targettype ------------------------------------------------------- 1 | 2 | fichinter | 5 | facture
// Save the intervention's id
$fromobject = object(); // Init the object
Modify the price of every product/service line with a coefficient
Here we will go through the creation and management of a custom field called coefficient that will change the total price by modifying it by the coefficient.
The preliminary and necessary step is to first create a custom field that will be used to modify the total price. Then, the following sub-chapters are all independent, thus you can only follow the ones that you require, eg: if you only need to change the price in your PDF documents, just create a custom field then jump to the sub-chapter to Implement the change of price in PDF.
Creation of the custom field called coefficient
First you have to create a custom field. We will create one for Client Invoice Lines.
When you go to client invoices in Dolibarr, you should then see something similar to this:
You can see that our coefficient field was successfully created.
Implementing the change of price in ODT templates
You can either create your own module, then create your own substitution function, but for the sake of simplicity in this tutorial, we will directly use the CustomFields substitution function. However, please remember that you will have to redo your changes everytime you will update the CustomFields module, so if you don't want to do that it would be better if you create your own module and substitution function.
At the very end of this function, but inside the customfields check:
But just before the ending bracket, you should add the following code:
if ($object->table_element_line === 'facturedet') { // First check that we are in the right module, we don't want to use coefficient for other modules if we didn't define the custom field there
$substitutionarray['line_price_full'] = $substitutionarray['line_price_ttc'] * $substitutionarray['cf_coefficient']; // multiply the total price with our coefficient
Implementing the change of price in PDF templates
First, we will create our own PDF template by copying an existing template, and then we will edit it to change the price of items.
Creating your own PDF template by copying an existing template
Go into the following folder: htdocs/core/modules/facture/doc/, then copy the file pdf_crabe.modules.php and name the new one pdf_crabecoeff.modules.php.
Then open it in your favourite editor, and change the following lines:
class pdf_crabe extends ModelePDFFactures // change pdf_crabe into pdf_crabecoeff
function __construct($db)
$this->name = "crabe"; // change "crabe" into "crabecoeff"
That's it, now you have your own PDF template!
Now you should enable your PDF template before doing anything else, by going into the Modules Administration panel, and into the Invoice admin page, then click on the ON button at the right of the crabecoeff entry to enable the template.
Now, let's proceed onto modifying the prices.
Changing the prices automatically in your PDF
You can now do pretty much anything you want in your PDF template, but I will give you a mean to automatically change the prices of every products with our coefficient, as well as the total price, without editing too much the template.
First, try to find the following code of line (should be inside the write_file() method):
Now, just copy/paste the following code below pdf_getInstance():
// Resetting every $object price because we will compute them anew
$object->total_ht = 0;
$object->total_tva = 0;
$object->total_ttc = 0;
// For each line of product/service, we will recompute all the prices
foreach($object->lines as $line) {
// Get the coefficient custom field's value for the current line
$coeff = $object->customfields->lines->{$line->rowid}->cf_coefficient;
// Recompute the price of this product/service line
$line->total_ht = $line->total_ht*$coeff; // compute no tax price
$line->total_tva = $line->total_tva*$coeff; // compute tax amount
$line->total_ttc = $line->total_ttc*$coeff; // compute tax included price
// Do the sum of all new products/services prices and tva (will be incremented with every product/service line)
$object->total_ht += $line->total_ht; // global no tax price
$object->total_tva += $line->total_tva; // global vat/tax amount
$object->total_ttc += $line->total_ttc; // global tax included price
That's it, now you should try to generate your PDF document, and you should get something like this:
Note: printing the coefficient as a column in your PDF document is also possible but will not be covered here because PDF templates will vary for every persons depending on your needs. For guidelines about how to do this, you can read the documentation on how to create a PDF template and how to use custom fields in PDF templates.
Hint: you should be looking inside the following conditional block, inside the write_file() method:
// Loop on each lines
for ($i = 0 ; $i < $nblignes ; $i++)
Implementing the change of price in the Dolibarr interface
Unluckily there is not (yet) any hooking context to modify how lines of products/services are printed, thus the only thing you can do is directly edit the htdocs/core/tpl/objectline_view.tpl.php template file, then load your customfield manually and print it the way you want using HTML formatting, for our example:
In objectline_view.tpl.php, find the following code:
And replace it by:
<?php
$linecf = new stdClass();
$linecf->id = $line->rowid;
$linecf->table_element = 'facturedet'; // you can use $this->table_element_line here instead of 'facturedet' if you want this feature to work for every module supported by CustomFields
// Modifying the TTC price and printing it on the Dolibarr's datasheet interface
echo price($line->total_ttc * $linecf->customfields->cf_coefficient);
This should produce something like this:
Technical note: here we are using customfields_fill_object() instead of customfields_fill_object_lines() (the latter being specifically adapted to lines and thus should theoretically be used here) for performance reasons because the template file we are editing is called in a loop, and customfields_fill_object_lines() should be called outside a loop (because it already does the job that is done by the loop), so here we 'tricks' the customfields_fill_object() function to avoid this loop by submitting 'facturedet' as a module by itself (when in fact it's a product lines table, but it works the same way nevertheless). This is a good demonstration of the flexibility of the CustomFields functions and methods.
