Install and configure OpenLDAP
Revision as of 12:07, 24 October 2012 by Eldy (talk | contribs) (→‎Setup server)
Ce chapitre ne concerne pas Dolibarr. Il contient un exemple d'instructions pour installer un annuaire LDAP qui pourra éventuellement être interfacé avec Dolibarr.
Install LDAP server
  • With Ubuntu or Debian, install package slapd and ldap.
  • With Windows, you can use the install program of OpenLDAP.
Once this is done, you have an empty LDAP server launched as a service.
Setup server
For Ubuntu, see page http://doc.ubuntu-fr.org/openldap-server
Otherwise the DN root, user and password to connect are available into file slapd.conf. Port may also be into this file, if not, it is default port value: 389.
Stop the service
Modify file slapd.conf to use your domain name (replace all dc=my-domain,dc=com by value of your choice).
Modify file slapd.conf also to add includes of schemas you will need to declare your LDAP objects.
include		./schema/core.schema
include		./schema/cosine.schema
include		./schema/inetorgperson.schema
include		./schema/nis.schema
Restart the service.
Tester le serveur
A l'aide d'un browser LDAP comme JXplorer, essayer de vous connecter au sevrer LDAP avec le user d'administration LDAP. Les identifiants de connexion par défaut seront donc:
  • Server: Localhost
  • Port: 389
  • User: cn=Manager,dc=yourdomain,dc=com
  • Password: secret
  • Base DN (optionnel): ne rien mettre ou mettre dc=yourdomain,dc=com
Créer votre arbre LDAP
L'étape suivante consiste à définir les informations à stocker dans l'annuaire LDAP et leur organisation.
Créer un fichier init.ldif contenant votre organisation. Par exemple:
# Organization
dn: dc=mydomain,dc=com
objectclass: dcObject
objectclass: organization
dc: mydomain
o: Description of annuary
description: The description of annuary
# Setting up container for Users OU
dn: ou=People,dc=mydomain,dc=com
objectclass: top
objectclass: organizationalUnit
ou: People
# Setting up container for groups
dn: ou=Groups,dc=mydomain,dc=com
objectclass: top
ou: Groups
Executer le fichier avec le compte administrateur LDAP:
ldapadd -f init.ldif -D "cn=Manager,dc=mydomain,dc=com" -w secret
