Module CustomFields Dev
CustomFields
Numero/ID of module 8500
User doc. of module Module_CustomFields
These notes are aimed to developpers who want to extend the functionnalities of the module or want to use it for extreme cases. This is not meant to guide implementers on how to implement and configure the module (see the related chapter for that).
If you are an implementer and just want to use CustomFields with its normal functions, you can read the user documentation of CustomFields.
Principles
CustomFields is simply a wrapper for SQL databases.
The module is based on SQL to manage the fields and most of the stuff. It uses and understands standard SQL.
The main principles of CustomFields are:
  • one SQL column = one Dolibarr field
  • one SQL type = one method to show and edit the field in Dolibarr
  • almost everything should be configurable from the configuration file
Goals
This module was made to provide an easy way to manage custom sql fields, not only for users and implementers, but also for developpers to use in their own module:
  • by easily adding the support of custom fields for your own module by using this module;
  • by reusing custom fields from another module in your own module;
  • by managing sql fields in your own module by using the CustomFields class (which will take care of everything from printing, editing to PDF/ODT templating).
So this module is not only an auxiliary of other modules, but it can also be the core part of your own module by using it as your SQL query class for fields.
SQL structure
A CustomFields table needs to respect three parameters that never change:
  • table's name (format: llx_*dolibarrmodule*_customfields where *dolibarrmodule* = table_element in conf_customfields.lib.php)
  • first column: rowid, which is the primary key for each field
  • second column: fk_*dolibarrmodule* which is the foreign key that links every customfields record to the Dolibarr's module that is associated (invoice, order, etc...).
Apart from the table's name and the first two special columns, every other columns are just standard sql columns that you can freely create, edit or delete as you want, from the module's administration page or from a third-party SQL management tool (such as phpMyAdmin).
You can also create more complex sql fields: constraints, foreign keys, transformations, other sql types, etc...).
Then the module will try to manage the sql fields you manually created the best it can:
  • by printing appropriate input fields in the Dolibarr gui interface.
  • by providing the developper an easy access to these fields in php (eg: $customfields->cf_myfield or $object->customfields->cf_myfield) for any use, including PDF templates and ODT templates, or in any php script (so that you can use these fields in your own module).
SQL Indexes
The module automatically adds an index on the primary key and foreign key (first and second columns).
To further optimize the performances of your database, and particularly the customfields tables, you may want to manually add indexes based on usage.
Also, you may add indexes on remote tables used by constrained fields, which could optimize even more the performances since constrained fields have the worst performance drawback for CustomFields.
SQL Compatibility mode
The module relies on referential integrity checks and foreign keys of your DBMS to keep the database clean and to provide the constrained fields feature. Referential integrity checks is part of the SQL standards and should be used whenever possible, which always was a main goal for CustomFields (to be respectful of SQL standards).
Unluckily, a few DBMS systems still don't support this critical functionality of the SQL standard, for example MySQL enables MyISAM engine by default, which doesn't support this feature.
In these cases, you can either do two things:
  • Switch to an engine which support referential integrity. For example with MySQL, you can enable InnoDB, which support referential integrity checks and foreign keys.
  • Use CustomFields compatibility mode (more infos below).
In the case your database does not support referential integrity checks, CustomFields will automatically switch to the SQL compatibility mode, which will allow you to use CustomFields even on databases where foreign keys are not possible.
In compatibility mode, you will get nearly all CustomFields advanced features such as Constrained fields, but the customfields' tables in the database won't be cleaned automatically (no delete on cascade, meaning that when you delete an object, the linked custom fields will still be kept in your database), and constrained fields won't be updated automatically on update.
Nevertheless, these missing cleanup functionalities won't be seen by your users because they will never be accessible: on deletion of an object, the custom fields won't ever be accessible again from Dolibarr's interface, and object's ids are never changed since Dolibarr also relies on this. Thus in compatibility mode, CustomFields will act just like normally, but your database will be a bit less clean.
JSON extension for extra options
Introduction to JSON in CustomFields
The relational model is very great to store and fetch data with a declarative language, and this is very powerful, but this model also imposes a few limitations, for example the relations must be well formatted and predefined.
That's why we finally implemented a JSON extension to manage extra options and associate them with custom fields. This allows to add many properties (or columns if you are more used to the relational model) on-the-fly without having to predefine them prior to storing and using them.
This allows to add an undefined number of columns/properties/extra options that will help manage special behaviours for custom fields. For example, it is currently used to allow to change the order of appearance of custom fields, and to store and manage remote table and columns datas for constrained fields on DBMS that do not support Foreign Keys checks.
We chose JSON over XML because the library are simpler and the data footprint smaller, and because CustomFields does not need advanced features of XML like XQuery, data typing and meta structures (at least not for now).
The other advantage is that php objects can directly be encoded into JSON without any preprocessing, and can then as straightly be decoded from JSON back into a php object.
A simple mean to encode and decode back an object into and from a storage place was the main requirement, and JSON (+ JSON libraries for PHP) meet this criteria.
Implementation of JSON
The implementation is very simple: a table called llx_customfields_extraoptions is created when you enable the CustomFields module, and this table only contains three columns:
  • table_name (varchar)
  • column_name (varchar)
  • extraoptions (blob)
(table_name, column_name) both forms the primary key of the table, and links to columns (custom fields) of other customfields tables. extraoptions is a blob, which allows to store the data as binary (as-is) without encoding (which solves a big problem of JSON which is encoding special and foreign characters, here there is no problem at all).
When fetching custom fields, the module simply JOIN the extraoptions table, which adds an extraoptions column for each custom field in the SQL result. Then it is quite easy to just json_decode() the data returned inside the extraoptions column.
This methodology allows to have all the advantages of a relational database, with the flexibility of a free-schema model:
  • everything is stored inside the database (only one storage place)
  • fixed columns allows for relational joining and optimization
  • thus queries (fetching) are optimised
  • at the same time, the extraoptions are automatically retrieved and associated with every custom field, and whenever needed they can be used
  • and thus we also get a flexible model to add extra (virtual) columns whenever needed without having to alter the relational database schema
Thus no critical information is and should be stored inside the extraoptions column because they would not be query-able, only extra options that are just used to tweak the management of those fields inside the PHP application should be stored. But this is a wonderful way to add non critical informations that still allows to develop more complex features and management for special custom fields.
CustomFields JSON API
Storing extra options
You can use the setExtra() method to set extra options of a custom field.
Eg:
$extra = new stdClass(); // instanciating an empty object
$extra->myproperty = 'Anything I want here'; // set a property/extra option like this
$extra->category->subcategory->prop = true; // we can set recursive properties, there's not any limit to own deep the hierarchy can be
require_once(DOL_DOCUMENT_ROOT.'/customfields/class/customfields.class.php');
$customfields = new CustomField($db, 'currentmodule');
$fieldid = 'mycustomfields'; // $fieldid can either be a column_name or an ordinal_position from information_schema.columns
$result = $customfields->setExtra($fieldid, $extra); // store the extra options inside the database
You can also use addCustomField() or updateCustomField() with an $extra object, and these functions will also call the setExtra() method.
Note: the extra options you set are appended to the one already stored in the database. However, you can overwrite them, just use the same name of property but with a different value.
Fetching extra options
Extra options are automatically fetched along with a custom field structure, decoded, and stored inside the extra sub-property of any field object, or CustomFields object.
When fetched, extra options are stored as a sub-object for the current field object (which itself is stored as a subobject of the CustomFields object if caching is enabled).
Eg:
$fields = fetchAllFieldsStruct(); // fetching fields structure will automatically fetch extra options at the same time. This works with fetchAllFieldsStruct() and fetchFieldStruct()
// Now that you fetched the fields structure, you can just access the extra options sub-properties:
print_r($fields->mycustomfield->extra); // will print all extra options for the field mycustomfield
print_r($customfields->fields->mycustomfield->extra); // you can also access the same field(s) directly from the CustomFields object if caching is enabled (default behaviour)
Modifying extra options
You can just combine the two previous points to edit extra options of a custom field: just load a custom field, edit on-the-fly the extra property with PHP code, and then store it back directly into the database:
$fields->mycustomfield->extra->newproperty = 'This is a new property'; // add a new property over the old extra options sub-object
$customfields->setExtra('mycustomfield', $fields->mycustomfield->extra); // store the modified extra options back into the database for future usage
CustomFields API
Introduction to CustomFields API
This chapter will cover the basics on how to manually and concretely use the CustomFields class to create/update/fetch/manage custom fields.
This will give you a better understanding of how CustomFields works, as well as giving you insights on how to use it for your own applications.
Prerequisite to use the CustomFields class
Before using the CustomFields class, you first must instanciate it. This is a necessary preliminary step before using any of the methods that will be covered inside this chapter, and thus will not be repeated, only shown once here.
// Include the CustomFields class (which contains the main API)
require_once(dirname(__FILE__).'/../class/customfields.class.php');
// Instanciate a CustomFields object
global $db; // the database handler created by Dolibarr
$table_element = 'currentmodule'; // where $table_element is the database's table name for the module, without the Dolibarr prefix (eg: for 'llx_facture', table_element is 'facture'). You can also find it inside the $object properties (just print_r() it).
$customfields = new CustomFields($db, $table_element); // instanciate the CustomFields class inside $customfields object
CustomFields keeps track of errors that can happen when executing methods and SQL queries inside the error and errors properties, which you can print with the printErrors() method:
// Do something with CustomFields before
if (count($customfields->errors) > 0) { // If there is at least one error
    $customfields->printErrors(); // print errors
// You can also print your own error message, in two manners:
// 1- submit your own message
$customfields->printErrors('Your own error message here'); // this will print ONLY your error message, using the Dolibarr's AJAX error dialog (standard way of printing errors)
// 2- append your message in the customfields errors
$customfields->errors[] = 'Your own error message to be appended with other CustomFields messages';
$customfields->printErrors(); // Here your error message will be appended, thus all error messages will be printed. This allows you for example to add more intelligible informations on a specific error.
General purpose SQL methods
CustomFields provide an interface to easily execute various common SQL requests, as well as your own custom SQL requests.
  • fetchAllTables() fetch a list of all the tables in the database
  • fetchPrimaryField($table) fetch the column_name (and only the column_name!) of the primary field of a table. You can then use fetchFieldStruct() with the column_name to get any information you want.
  • fetchAny($columns, $table, $where=, $orderby=, $limitby=) allows you to issue any simple SQL query command, for example fetchAny('*', 'sometable') is equivalent to SELECT * FROM sometable; (but then everything is managed automatically and result is returned to you)
  • executeSQL($sql, $eventname) to execute any SQL query you want, this will return you a resource (and NOT a processed nuplet like fetchAny!). $eventname can be anything, it's just for Dolibarr logging facility.
  • executeMultiSQL($sql, $eventname) to execute multiple SQL queries
  • fetchFieldStruct($id=null, $nohide=false, $table=null, $cachepath=null) allows you to fetch the field's SQL structure of not only custom fields, but of any database's column using the $table variable. Eg: fetchFieldStruct('mycolumn', true, 'mytable');
  • probeTable($table) helps you to check if a table exists in the database
  • fetch_object($resource) will return a PHP object from a $resource, similarly to mysql_fetch_object() but with two advantages: it works on several DBMS (not only mysql), and it always return lowercase properties names (else depending on the configuration of the DBMS, the request can return uppercase or mixed case properties names).
  • escape() and reverse_escape() are similare to mysql_real_escape but is reversible and DBMS-independent (so you can use it with other DBMSes).
Managing CustomFields structure
The first step into CustomFields is to create and manage the structure of a custom field.
Creating a custom field
To create a custom field, you can use the addCustomField() method.
$rtncode = $customfields->addCustomField($fieldname, $type, $size, $nulloption, $defaultvalue = null, $constraint = null, $customtype = null, $customdef = null, $customsql = null, $fieldid = null, $extra = null);
This will take care of forging the (complicated) SQL query with the forgeSQLCustomField() method, and will return you an error if there was a problem.
Updating a custom field
To update a custom field, you can use the updateCustomField() method:
updateCustomField($fieldid, $fieldname, $type, $size, $nulloption, $defaultvalue, $constraint = null, $customtype = null, $customdef = null, $customsql = null, $extra = null);
Note: the updateCustomField() and addCustomField() methods can both be used since updateCustomField() is in fact an alias for addCustomField(). CustomFields will automatically detect if a custom field already exists, and update it if that's true, or create it.
Note2: updating a custom field will automatically take care of the constraints and foreign keys on its own, thus you can change the foreign key, or remove it altogether if set to null.
Delete a custom field
You can easily delete a custom field by column_name or by ordinal_position:
$rtncode = $customfields->deleteCustomField($id);
Note: constraints and foreign keys will also be deleted automatically so you shouldn't encounter any error.
Fetch one custom field's SQL structure
To get the SQL structure of a custom field, which can be quite useful to know for example its datatype or if it has a foreign key, or accepts null values, you can use the fetchFieldStruct() method:
fields = $customfields->fetchFieldStruct($id=null, $nohide=false, $table=null, $cachepath=null); // where $id can be a column_name, an ordinal_position from information_schema.columns or null if you want to fetch all the columns at once
This method will either return null, either a single field object, either an array on field objects.
Note: this function will use caching by default to accelerate future results, but you can disable it, or even change the default cache path. For more informations please read the comments in the source code.
Fetch several custom fields' SQL structures
Use the fetchAllFieldsStruct() method, which is an alias for fetchFieldStruct():
$rtncode = $customfields->fetchAllFieldsStruct($nohide=false, $table=null, $cachepath=null);
Note: this method will always return an array of fields objects, even if only one is found (for more consistency), and this is the main difference with fetchFieldStruct(null).
Managing custom fields records
Now that you know how to create and manage the structure of custom fields, we can proceed on to managing the records.
Creating a custom field's record
Simply use the create() method:
$rtncode = $customfields->create($object);
$object must be an object containing as its properties the customfields data.
For example, if you have a field named mycustomfield, your object must have $object->mycustomfields defined.
This method will store in the database ALL the custom fields that were created/edited and with a valid value (eg: an empty value for a field that does not accept null value is invalid) AT ONCE! So you can modify all the columns of one record at once, but not several records at once.
Concretely, this is very useful with Dolibarr, because modules tends to store everything inside a single object generally called $object, and CustomFields tries to hook onto $object, so that you can just pass $object as is to create() and it will save all the custom fields.
But you can also create an empty object with $object = new stdClass(); and then manually fill the custom fields records with whatever you want, and then call the create() method, this will work as well!
You can also just modify only one column of one record, by just specifying one custom field column_name in your $object. The other custom fields that are not specified won't be created/modified.
Updating a custom field's record
Use the update() method, which is an alias for the create() method:
$rtncode = $customfields->update($object);
As noted above, update() is an alias of the create() method, which means that CustomFields will try to detect by itself if a record needs to be updated or created.
Deleting a custom field's record
Use the delete() method:
$rtncode = $customfields->delete($id); // where $id is = to fk_moduleid column, NOT rowid
Fetching a custom field's record
Just use the fetch() method:
$records = $customfields->fetch($id=null);
Where $id can either be = fk_moduleid (NOT rowid), or null to fetch all the records at once.
This method will either return null, a single record object, or an array of records objects.
Fetching all custom fields' records
Use the fetchAll() method, which is an alias for fetch():
Note: this method will always return an array of records object, for more consistency (and this is the main difference with fetch(null) ).
Printing custom fields
The API can also automatically manage the printing of custom fields, and also the management of the input forms for users to input new values, with the best adapted HTML form based on the custom field's data type.
Input forms
CustomFields provides a neat way to print input fields that are adapted to the SQL data type of your custom fields as well as the possible and formatted values (for example: a not null enum will be printed as a HTML select list without an empty option).
So you don't have to bother how your data will be presented to the user nor how it will be processed.
Printing an input form adapted to the field's data type
showInputField() is a sort of converter customfieldstructure -> HTML input field.
Use the showInputField() method to print the right input form for a custom field.
print $customfields->showInputField($field, $currentvalue=null, $moreparam='');
showInputField() takes 3 parameters:
  • $field is a CustomFields structure object (eg: returned by fetchFieldStruct()) and is necessary to detect the right datatype and the possible values.
  • $currentvalue is the current value if you want to preselect a value (for example if the user already defined a value, you can reload it here). This is optional, in case it is not defined, either a null/empty value will be chosen, or either the default value defined when creating the custom field.
  • $moreparam is used to add more HTML attributes, if you want for example to add some css styling or whatever you want.
showInputField() only prints ONE HTML input field, thus you have to enclose it/them by your own HTML form.
eg:
print '<form method="get" action="?">';
print '<input type="hidden" name="customtoken" value="ABCDEFGH" />'; // example of a custom hidden HTML input field, that can be used to pass a token for example
// Loop over each custom fields (you have to load them before with $customfields->fetchAllFieldsStruct()
foreach ($customfields->fields as $field) {
print '</form>';
You can also store the resulting HTML input field and process it by a regexp for example:
$myhtmlfield = $customfields->showInputField($field, $currentvalue=null, $moreparam='');
preg_replace($myhtmlfield, ..., ...);
Printing an input form for a custom field
showInputForm() is a function used to print a single (and only one!) custom field with an adapted HTML input field, but enclosed by a HTML form. This is used for example when you want to allow to edit a single custom field but not the others.
showInputForm() is in fact a wrapper for showInputField(), thus it will call showInputField() and simply enclose it by a form.
print $customfields->showInputForm($id, $field, $currentvalue=null, $idvar='id', $page=null, $moreparam='');
Printing in documents
simpleprintField() simpleprintFieldPDF() findLabel() findLabelPDF()
Facade API
The Facade API was made to ease the usage of the CustomFields class with the Dolibarr system. It provides a neat way to do many operations with single commands, and will automatically manage the loading of the CustomFields class, and its usage with many optimizations.
customfields_fill_object()
You can load the Facade API and then use the customfields_fill_object() to automatically fetch the fields structures and the records, and also automatically link to remote fields when a constrained field is found. This is an all-in-one solution to easily fetch CustomFields datas, and is also optimized to fully use caching and other special properties of the CustomFields class.
Concretely, you just have to include the Facade API, then pass the customfields_fill_object() with a Dolibarr $object, and the Facade API will return a CustomFields object with appended the custom fields records and also the custom fields' SQL structures.
$customfields = customfields_fill_object($object);
  • $object will then include the custom fields records associated with this object (eg: $object->customfields->cf_yourfield).
  • $customfields will be a CustomFields object containing the fields structures (eg: $customfields->fields->yourfield).
You can also call any CustomFields function if you need to using the $customfields object, eg: $customfields->simpleprintField($object->customfields->cf_yourfield);
Note: $object can also be a dummy object containing only two properties that are required: $object->id and $object->table_element.
For more informations on pratical usages of this function, please read the user documentation on how to implement CustomFields in php code.
customfields_fill_object_lines()
Similar to customfields_fill_object() for normal custom fields, there is also a customfields_fill_object_lines() to fetch custom fields associated with lines of products/services. This function is also optimized and it is strongly advised to use it and to not try to fetch manually this kind of custom fields (ie: associated with lines of products/services rather than objects), because there are a lot of optimizations going on behind the scene and that are very hard to do manually.
// Filling the $object with customfields for lines of products/services (you can then access them by doing $object->customfields->lines->$lineid->cf_yourfield)
$customfields = customfields_fill_object_lines($object);
Requirements: $object can be a dummy object but must contain at least 2 properties: $object->id and $object->table_element_line.
Architecture
Here is a full list of the CustomFields packaged files with a short description (for a more in-depth view just crawl the source files, they are full of comments):
Core files
files that are necessary for the CustomFields to work, they contains the core functions
  • /customfields/admin/customfields.php --- Administrator's configuration panel : this is where you create and manage the custom fields definitions
  • /customfields/class/actions_customfields.class.php --- Hooks class : used to hook into Dolibarr core modules without altering any core file (can be used to hook into your own modules too). Also used to preprocess the parameters before calling the printforms library.
  • /customfields/class/customfields.class.php --- Core class : every database action is made here in this class. You can find some printing functions because they are very generic.
  • /customfields/conf/conf_customfields.lib.php --- Configuration file : contains the main configurable variables to adapt CustomFields to your needs or to expand its support to other modules and more native sql types.
  • /customfields/conf/conf_customfields_func.lib.php --- Auxiliary functions library to read and manage config variables
  • /customfields/core/modules/modCustomFields.class.php --- Dolibarr's module definition file : this is a core file necessary for Dolibarr to recognize the module and to declare the hooks to Dolibarr (but it does not store anything else than meta-informations).
  • /customfields/core/substitutions/functions_customfields.lib.php --- CustomFields substitution class for ODT generation : necessary to support customfields tags in ODT files
  • /customfields/core/triggers/interface_50_modCustomFields_SaveFields.class.php --- Core triggers file : this is where the actions on records are managed. This is an interface between other modules and CustomFields management. You should not modify this file but you should add your triggers in $triggersarray inside conf_customfields.lib.php, but if you really have a special need and know what you do, you can edit this file to directly add your own triggers. Also, if CustomFields are shown in the forms but cannot be modified nor saved, then probably this trigger file is not detected by Dolibarr (maybe you can try to lower the number 50 to raise the priority?).
  • /customfields/fields/customfields_fields_extend.lib.php --- Overloading functions library with users functions: this is where implementers can use their own php code to manage the custom fields they want (one function per action and per field).
  • /customfields/langs/code_CODE/customfields.lang --- Core language file : this is where you can translate the admin config panel (data types names, labels, descriptions, etc.)
  • /customfields/langs/code_CODE/customfields-user.lang --- User defined language file : this is where you can store the labels and values of your custom fields (see the related chapter)
  • /customfields/lib/customfields_aux.lib.php --- Simplifier library to easily use CustomFields class to populate an $object with custom fields datas (Facade design pattern). This is what you should use for most of your needs.
  • /customfields/lib/customfields_printforms.lib.php --- Core printing library for records : contains only printing functions, there's not really any core functions inside but it allows to manage the printing of the custom fields records and their editing.
  • /customfields/sql/*.sql --- Unused (the tables are created directly via a function in the customfields.class.php) - but the sql files are still valid, they were used as squeletton in the first designs.
PDFTest module
optional module to append a page listing all custom fields values on newly generated PDF documents. To be used to test if custom fields are working correctly before making one's own template.
  • /customfieldspdftest/class/actions_customfieldspdftest.class.php --- Main functions library and hooks class, to hook onto pdf generation. Contains the PDFTest functions.
  • /customfieldspdftest/core/modules/modCustomFieldsPDFTest.class.php --- Module descriptor for Dolibarr
Runtime outline
Here is an outline of how CustomFields works: what functions will be called and why:
- At admin page:
  • No external function call (apart for some icons or needed admin functions like for tabs), everything that is done are sql queries via CustomFields class (to fetch and modify the sql columns in the customfields tables).
- At printing:
  • Module's hook formObjectOptions calls Dolibarr's hookmanager
  • Hookmanager calls CustomFields /class/actions_customfields.class.php, function formObjectOptions() of CustomFields
  • Preprocess a few parameters (mainly the $action) and calls customfields_print_forms()
  • customfields_print_forms() preprocess all the hook's parameters and assimilate them with the CustomFields's configuration parameters (there's no connection to the database at this stage, only parameters preprocessing), then calls /lib/customfields_printforms.lib.php, functions customfields_print_creation_form() or customfields_print_datasheet_form
  • both customfields_print_creation_form() lookup the database using CustomFields class and prints empty custom fields; customfields_print_datasheet_form() lookup the database using CustomFields class, fetch the values of the custom fields and prints them;
- At edition:
  • Same steps as At printing
  • then customfields_print_datasheet_form() process the custom field being edited differently than the others: if editing, it prints the html input field (to enter a new value), or if saving it just saves the data into the database by calling the CUSTOMFIELDS_MODIFY trigger and then continue to print the other fields normally.
  • CUSTOMFIELDS_MODIFY trigger calls $customfields->update($newrecord);
- At creation (saving):
  • Module's creation trigger MYMODULE_CREATE calls Dolibarr's run_trigger()
  • Dolibarr run_trigger() calls CustomFields trigger file /core/trigger/interface_50_modCustomFields_SaveFields.class.php, function run_trigger()
  • CustomFields's run_trigger() assimilate the given parameters with the CustomFields's config parameters, and if the trigger is found in $triggersarray, then the appropriate action is taken (by default: _CREATE or another standard action if recognized), if not in $triggersarray, the function will still try to automatically detect the appropriate action by detecting MYMODULE_ALISTOFACTIONS with a regular expression.
  • The appropriate action is then done (creation in this case) by calling $customfields->create($record).
- At edition or creation of product lines:
  • Similar to At edition but with hooks: formCreateProductOptions and formEditProductOptions.
- At ODT document generation and substitution:
  • Module's ODT generator calls for Dolibarr's function complete_substitution_array(), which then calls for CustomFields substitution file /core/substitution/functions_customfields.lib.php, function customfields_completesubstitutionarray()
  • CustomFields's function customfields_completesubstitutionarray() calls the simplifier library customfields_aux.lib.php, function customfields_fill_object() and make the substitution inside the $substitutionarray.
- At ODT document generation and substitution for product lines:
  • Same as the previous point but this function is called for every product lines, and thus the data is cached. Also the simplifier function is here called customfields_fill_object_lines(), and the CustomFields's substitution function called customfields_completesubstitutionarray_lines().
How to add the support of a new module
There are two cases: either the module already implements hooks, and you just have to configure CustomFields to support it, or either the module does not implements hooks nor triggers.
This chapter will guide you through the steps to make any module supported by CustomFields (be it a Dolibarr core module or your own module).
Preliminary test
This preliminary test will allow you to know at a glance how much work needs to be done in order to make your module supported by CustomFields, and it will also give you all the config parameters if they are available.
Important note: this test will only give data about hooks, which is the main part to make CustomFields work for your module. But for triggers, there is no way to test, so you will have to check the triggers manually (either by testing if the custom fields are saved at creation page, or by looking at the source code of the objects classes).
Edit the php script of the module (check the URL when you access the module's datasheet or creation page - attention both are two different pages, so you have to do this twice), then put this at the very end of the php script:
// CustomFields debuglines to show config parameters for current module
print("<pre>"); // html nice output
print("table_element: {$object->table_element} - table_element_line: {$object->table_element_line} - contexts: ");
print_r($hookmanager->contextarray);
print(" - conf hooks_modules: ");
print_r($conf->hooks_modules);
print(" - hooks attached: ");
print_r($hookmanager->hooks);
print(" - user rights: ");
print_r($user->rights);
print("</pre>");
Now reload the page, and scroll at the very bottom. You should see some informations about the module.
Depending on the data available, you will know what you have to do:
  • If there's no table_element: $object is not defined, try to find how is called the main object variable and replace $object by this variable in the debug code given above (eg: in Agenda, the object variable is called $agenda and $agendacomm).
  • If there's no table_element_line: either there's no products lines for this module, either the main object variable is not called $object (see the previous point). One last case is that the object is not standard and does not store table_element_line (the name of the table that stores its products lines), in which case you have to manually add it in the class (eg: $this->table_element_line = 'something').
  • If there's no contexts: the hookmanager is not defined, and probably there's no hook at all in this module, so you'll have to implement them by yourself. Jump to Module_CustomFields_Dev#Hooks.
  • If there is a list of contexts but the module cannot be found in the list: the hookmanager is defined but the module has not defined a context, you still have to implement the hooks. Jump to Module_CustomFields_Dev#Hooks.
  • If there's no conf hooks_modules: this variable is not necessary, empty or not it doesn't matter. But if you see customfields and/or customfieldspdftest inside the list, it is a confirmation that CustomFields indeed is hooking the module correctly.
  • If there is no $user->rights: there is either no standard security implemented in this module, or either the variable is called with another name. If there is no security, you don't need to configure it in CustomFields, but if there is a security, you need to find how the variable is called (like $object can get another name sometimes).
  • If there is $user->rights but the module can't be found in the list: either the name for the rights is different (this often happens, the rights array is not yet standardized), or either the rights are hardcoded into the module's code (rights should be announced to the $user->rights array, but sometimes it happens that the dev forgot to do so, and thus the right is entirely hardcoded and you can't find it in the dynamic rights array). In any of these two cases, you will have to manually read the module's code to find the right. Also, maybe there is no security implemented, but since $user->rights is declared this is less probable.
Here is an example of output on a correctly hooked module (invoice):
table_element: facture - table_element_line: facturedet - contexts: Array
    [0] => searchform
    [1] => leftblock
    [2] => toprightmenu
    [3] => invoicecard
 - conf hooks_modules: Array
    [customfields] => invoicecard:propalcard:productcard:ordercard:thirdpartycard:contactcard:ordersuppliercard:invoicesuppliercard:membercard:actioncard:projectcard:projecttaskcard:contractcard:interventioncard:doncard:tripsandexpensescard:taxvatcard:expeditioncard:invoicecard:propalcard:ordercard:ordersuppliercard:invoicesuppliercard
    [customfieldspdftest] => Array
            [0] => pdfgeneration
            [1] => ordersuppliercard
 - hooks attached: Array
    [invoicecard] => Array
            [customfields] => ActionsCustomFields Object
 - user rights: stdClass Object
    [user] => stdClass Object
                    [lire] => 1
                    [creer] => 1
                    [password] => 1
                    [supprimer] => 1
                    [export] => 1
            [self] => stdClass Object
                    [creer] => 1
                    [password] => 1
            [user_advance] => stdClass Object
                    [readperms] => 1
                    [write] => 1
            [self_advance] => stdClass Object
                    [readperms] => 1
                    [writeperms] => 1
            [group_advance] => stdClass Object
                    [read] => 1
                    [readperms] => 1
                    [write] => 1
                    [delete] => 1
    [facture] => stdClass Object
            [lire] => 1
            [creer] => 1
            [invoice_advance] => stdClass Object
                    [unvalidate] => 1
                    [send] => 1
            [valider] => 1
            [paiement] => 1
            [supprimer] => 1
                    [export] => 1
    [propale] => stdClass Object
            [lire] => 1
            [creer] => 1
            [valider] => 1
            [propal_advance] => stdClass Object
                    [send] => 1
            [cloturer] => 1
            [supprimer] => 1
            [export] => 1
    [produit] => stdClass Object
            [lire] => 1
            [creer] => 1
            [supprimer] => 1
            [export] => 1
    etc... a lot of other rights...
When you are finished with implementing the support of CustomFields in the module, you should delete these debug lines.
Implementing the support of CustomFields in the module
If there is a module you want to implement the support of CustomFields, but does not yet has the required components, here is a guide on how to implement these components.
Hooks
Implementing hooks will allow custom fields to appear on your module's page. They will also be editable and they will save the data. For creation, you need to use a trigger (see the subchapter below).
First you should be familiar with the way that hooks are implemented in modules. If you don't, please first read the hooks documentation.
An example case of implementation of hooks into a Dolibarr core file can be found in the CustomFields Example Cases wiki page.
Datasheet hook
To implement CustomFields in your module, you must initialize the hook manager, then use the following hook context:
  • formObjectOptions
This hook must be placed everywhere in your code where you want custom fields to appear (eg: on the creation page and datasheet view page).
Note: Generally, you will have to place the hook just before the end of a table tag (), so if you don't know where to place it (eg: if you're implementing CustomFields on a Dolibarr core module), just search for this tag in the page shown in the url (eg: /htdocs/commande/fiche.php).
Eg: First load the hookmanager at the beginning of your php script:
$hookmanager->initHooks(array('yourmodule'));
Then place the hook as many times as required:
// ... a lot of php code ...
print '</td></tr>'; // end of the last row of a table
// Other attributes
$parameters=array('colspan' => ' colspan="3"'); // specifying the colspan is optional but will help CustomFields know how to correctly print the table
$reshook=$hookmanager->executeHooks('formObjectOptions',$parameters,$object,$action);    // Note that $action and $object may have been modified by hook
print '</table>'; // end of the table, this is what you're looking for, place the hook just above
// ... a lot of php code ... redo the same if you find another </table> and there's a page where there's no custom fields but you want to place custom fields on there
Note2: If after implementing the hook you receive an error or custom fields don't appear, you may have to change $object to another variable, depending on what is called the main object (eg: in Agenda it's called $action and $actioncomm).
Lines hooks
For product lines, you should anyway use the product lines template files: htdocs/core/tpl/freeproductline_edit.tpl.php
If you don't, you can still manually implement the required hooks, what is required is that you supply $line (which is the current line object being processed) in the $parameters array:
$parameters=array('line'=>$line,'fk_parent_line'=>$line->fk_parent_line);
echo $hookmanager->executeHooks('formEditProductOptions',$parameters,$this,$action);
Hooks names:
  • formEditProductOptions
  • formCreateProductOptions ($line is not required here, because we create a new product line! you can leave $parameters=array(); empty).
Note: there's no hook for viewing, because showing the customfields will clutter the visual field, but if you really want you can also do it by adding a formViewProductOptions hook.
Triggers
First you need to know how to implement triggers in Dolibarr. For more informations about how to implement triggers in your module, please read the triggers wiki page.
Implementing triggers on your module will allow CustomFields to save the fields at creation (datasheet edition is already managed by hooks).
You need to implement 3 triggers: - on creation of object - eg: YOURMODULE_CREATE - on creation of lines - eg: YOURMODULELINE_INSERT (optional, only if your module has product lines) - on update of lines - eg: YOURMODULELINE_UPDATE (optional, only if your module has product lines)
Note: you need to supply the sql id of the newly created object before calling the trigger.
Eg:
$this->id = $this->db->last_insert_id(MAIN_DB_PREFIX."yourmodule_table_element");
// Appel des triggers
$result=$interface->run_triggers('YOURMODULE_CREATE',$this,$user,$langs,$conf);
if ($result < 0) {
    $error++; $this->errors=$interface->errors;
// Fin appel triggers
Note2: if it's a Dolibarr core module, you can easily find the right place to put the trigger by searching for 'create sql' in the class subfolder (eg: URL is /htdocs/commande/fiche.php, the class is in /htdocs/commande/class/commande.class.php).
Note3: CustomFields also supports a few other triggers like _CLONE, _UPDATE, _MODIFY, but they are not required and may not work depending on how your module works to manage these actions.
Configuring CustomFields to support the module
Preliminary work
You need to get the parameters of this module, and you will then put them in the CustomFields configuration file (conf_customfields.lib.php).
Getting the parameters automatically
You can use the preliminary test to easily get all those parameters.
Getting the parameters manually
To configure CustomFields to support a module, you need at least 5 parameters:
  • the module's table_name (name of the sql table where the module stores its datas)
  • the module's context (name given by the module to the hookmanager)
  • the module's idvar (name of the variable that holds the sql row id of the record)
  • the module's trigger action(s) (triggers on creation and update, see the related chapter above)
  • the module's rights (for security purposes)
To get these parameters manually, you can take a look inside the code of the module's files you want to implement:
  • module's table name: either find it by yourself in the database (looks like llx_themodulename) or by printing it in actions_customfields.class.php by adding print_r($parameters) and search for $parameters->table_element
  • module's context: search for "callHooks(" without the quotes or take a look at the wiki: http://wiki.dolibarr.org/index.php/Hooks_system
or you can get it by printing it in the /htdocs/customfields/class/actions_customfields.class.php by adding print_r($parameters) and search for $parameters->context
  • module's trigger actions: search for "run_triggers(" or take a look at the wiki: http://wiki.dolibarr.org/index.php/Triggers#List_of_known_triggers_actions
  • module's idvar: look at the url when you access one of the module's record, and you should see something like fiche.php?xxxid=12 - you need the xxxid (eg: socid, facid, etc.).
  • module's security: in the page shown in URL when accessing the module's datasheet, edit this file and add print($user->rights), then in the list try to find the correct right (generally something like $user->modulename->creer). You can also try to search for $user->rights in the sourcecode of this module.
With these values, edit the config file (/htdocs/customfields/conf/conf_customfields.lib.php), particularly the $modulesarray and $triggersarray variables:
Configure hooks and main parameters
Add every parameters except triggers in the $modulesarray:
$modulesarray = array(
                      array('context'=>'invoicecard', 'table_element'=>'facture', 'idvar'=>'facid', 'rights'=>array('$user->rights->facture->creer')), // Client Invoice
                      array('context'=>'membercard', 'table_element'=>'adherent', 'idvar'=>'rowid', 'rights'=>array('$user->rights->adherent->creer'), 'tabs'=>array('objecttype'=>'member_admin', 'function'=>'member_admin_prepare_head', 'lib'=>DOL_DOCUMENT_ROOT.'/core/lib/member.lib.php')), // Members / Adherents
                     ); // Edit me to add the support of another module - NOTE: Lowercase only!
There are also a lot of others parameters you can give to CustomFields so that the module gets better managed or to add a few other functionnalities, here is a non-exhaustive list:
  • context: name of the module's context.
  • table_element: name of the sql table that holds the object's datas.
  • idvar: name of the variable that holds the id of the object in the sql database (by default 'id' or 'rowid').
  • rights: prevent the custom fields to be editable unless all the rights set here are enabled (preventing custom fields to be viewed is useless because they won't show anyway if the page can't be loaded due to insufficient rights, so this is directly handled by the module).
  • tabs=>array(objecttype, function, lib, tabname, tabtitle): used to embed CustomFields's admin panel into another module's admin page.
Configure creation triggers
Add the triggers in $triggersarray: $triggersarray = array("order_create"=>"commande",
                      "yourmodule_triggeraction1"=>"yourmodule_tablename",
                      "yourmodule_triggeraction2"=>"yourmodule_tablename");
Note: generally you will be looking to implement the _CREATE.
Note2: if a triggeraction is not recognized by CustomFields (eg: mymodule_addpayment) then by default CustomFields will assimilate it to a _create action (it will create and save the values for the custom fields, just for a module's creation page).
Configuration troubleshooting
  • If you cannot see the custom fields appear on your module's page, this means the hooks are not implemented or configured in CustomFields, please read the related chapters.
  • If the custom fields appear on the datasheet but there's no edit button icon: the module implements security but you did not configure it properly in CustomFields, please find the right security in $user->rights and set it in conf_customfields.lib.php.
  • If the custom fields appear on the creation page but are not saved: you forgot to set the trigger in $triggersarray, or the creation trigger does not exist for this module and you have to implement it. Jump to Module_CustomFields_Dev#Triggers.
  • If the custom fields appear on the datasheet but not on the creation page (or vice versa): A hook is missing on the page where the custom fields do not appear. Jump to Module_CustomFields_Dev#Hooks.
  • If the custom fields appear on the datasheet with the edit button, but when the edit button is clicked, everything disappear: either the $idvar is not properly set (look at the URL to know if you need to set idvar), or the hook is not properly made ($object is not defined and it's called by another name, but the hook use $object instead of the correct variable).
  • If the custom fields appear on the datasheet with the edit button, can be edited but cannot be saved (the data is not saved): same as the previous point: either $idvar or $object bug.
Also you might find useful to enable php errors to better track errors if that's not already done.
Example cases
TO DO
To Do
Nothing here!
Should do
  • Checkbox (multiple checkboxes, one for each possible value) and multiselect (big select and can use SHIFT to multiselect) (store in XML file) (but impossible with constrained fields, can't store multiple foreign keys ids in one single sql field, but would work for other types like enum)
use fieldset, input checkbox and label for, eg:
   <fieldset><legend><label for="cf_productslist"> $langs->trans('cf_productslist')</label></legend>
   <input type="checkbox" name="cf_productslist_choice1" value="1" id="cf_productslist_choice1" /><label for="cf_productslist_choice1"> $langs->trans('cf_productslist_choice1')</label>
<input type="checkbox" name="cf_productslist_choice2" value="1" id="cf_productslist_choice2" /><label for="cf_productslist_choice2"> $langs->trans('cf_productslist_choice2')</label>
etc... </fieldset>
  • Refactor the trigger array: merge it with the modulesarray (along with a new way to specify which customfields trigger action a trigger should correspond, eg: 'linebill_insert'=>'customfields_create').
  • Add a javascript options values generator for the enum type (a hidden input that would be shown only when DropdownBox type is selected and that would permit to add options by clicking a plus button).
  • Replace triggers in customfields class by hookmanager.
  • Replace extend class by hookmanager if possible (but how to simulate the *full switch?).
Known bugs
  • in product and service modules, if you edit a field, the proposals and other fields below won't be shown, you need to refresh the page. This problem resides in Dolibarr I think (since we are simply using a hook).
  • ficheinter (Intervention module) custom fields will stay in create mode just after create page is submitted (this is because of the $action that is not standard - $action=edit or something).
  • after the edition or creation of a custom field for product lines, the fields in the creation zone are still prefilled with the last entered values of the custom fields (they should be empty, but the problem is that CustomFields automatically reload the last values entered in case there is an error, and the problem lies in the fact that after the creation/edition of a product line, there is absolutely no way to know if the page was reloaded due to an error or if everything is OK). Usually with other modules and mechanisms of Dolibarr, after creation/edition, the page is reloaded and $action is changed, but here it doesn't.
Maybe solution: look at the $object->$error or $object->$errors? but this is not a safe way, the variable name may change, or the error may be emptied, or may not even be set altogether depending on the error...
Never/Maybe one day
  • Add Upload field type (almost useless since we can attach files).
  • Add support for repeatable (predefined) invoices (the way it is currently managed makes it very difficult to manage this without making a big exception, adding specific functions in customfields modules that would not at all will be reusable anywhere else, when customfields has been designed to be as generic as possible to support any module and any version of dolibarr, because it's managed by a totally different table while it's still managed by the same module, CustomFields work with the paradigm: one module, one table).
  • AJAX? (but only optional, because else it won't work for mobile phones and tablets)
  • Add an AJAX select box for constrained values : when a constrained type is selected and a table is selected, a hidden select box would show up with the list of the fields of this table to choose the values that will be printed as the values for this customfield (eg: for table llx_users you could select the "nom" field and then it would automatically prepend "nom_" to the field's name).
