// ... php code ...
  function __constructor($db) {
// ... php code ...
    $this->name = "crabe";
into:
// ... php code ...
// ... php code ...
    $this->name = "customfields";
 *   	\brief      Show the customfields in a new page
 *   	\param      pdf     		PDF factory
 * 		\param		object			Object invoice/propale/order/etc... (CustomFields simpler functions will automatically adapt)
 *      \param      outputlangs		Object lang for output
    global $conf;
    // Init and main vars
    $pdf->SetY($pdf->GetY()+1);
    // Printing the customfields
        // Get translated label
    return 1;
Alternative function (with a bit less functionalities, but more controllable):
 *   	\brief      Show the customfields in a new page (used to debug if CustomFields setup is correct)
 * 		\param		object			Object invoice/propal/product/whatever...
            if (empty($object->table_element) or empty($object->id)) {
                $pdf->MultiCell(0,3, "Current \$object is not compatible with CustomFields, could not find table_element or id.", 0, 'L');
                return 1;
    include_once(DOL_DOCUMENT_ROOT.'/customfields/class/customfields.class.php');
    $customfields = new CustomFields($this->db, $object->table_element);
            // Fetching custom fields records
            $fields = $customfields->fetch($object->id);
            if (!isset($fields)) {
                $pdf->MultiCell(0,3, "No custom field could be found for this object. Please check your configuration (did you create at least one customfield and set a value in the current datasheet?)", 0, 'L');
                return 1;
            } else {
                foreach ($fields as $key=>$field) {
                        $translatedname = $customfields->findLabelPDF($key, $outputlangs); // label of the customfield
                        $value = $customfields->simpleprintFieldPDF($key, $field, $outputlangs); // value (cleaned and properly formatted) of the customfield
                        $pdf->MultiCell(0,3, $translatedname.': '.$value, 0, 'L'); // printing the customfield
    return 1;
// Pied de page
$pdf->AliasNbPages();
// CustomFields
        $pdf->AddPage();
        $pagenb++;
Conditions categories
  • static condition: choices are restrained on a condition that never changes (eg: only show third-parties that are suppliers, or lowercase all data on sql insertion, or check that a field is above a certain number, etc.).
  • semi-dynamic condition: choices that are constrained on a static table but based on the value of another field/customfield.
  • dynamic: everything is dynamic: choices are based on a subfield of a field of the current module, so that there's no material table and it's impossible to create a view (because you would need to create one view per id) (eg: show only the contacts attached to the third-party being accessed)
  • timed condition: a condition that is based on time or recurrence (eg: at 5:00 AM delete old records, etc..)
Conditions solutions
Static condition
  • View: create a view on the table based on the condition, and then create a custom field constrained on this view (which is just like any table), eg: only show third-parties that are suppliers:
SELECT *
FROM llx_societe
WHERE fournisseur=1;
  • Check
  • Trigger
  • SQL Transformations
  • CustomFields's overload functions
Semi-dynamic condition
  • View
  • Check
  • Trigger
Dynamic condition
  • Making your own module, which calls the CustomFields class
Timed condition
  • SQL scheduled events
  • Cron job
Overloading functions
1,les 2 alpes,isère
2,chamrousse,isère
3,alpe d'huez,isère
4,vars,alpes du sud
5,risoul,alpes du sud
etc...
In CustomFields's admin panel, we create two custom fields: 1-secteur: returns the list of all zones - type DropdownBox: enum('- Aucun','Alpes du Sud','export','Haute-Savoie','Isère', etc...) 2-station_a: returns the list of all ski resorts - type constraint on llx_k_station
$result=$db->query($sql);
  if ($result) {
    $i = 0;
    $myarray = array();
    while ($i < $num)
      $i++;
    $value = $myarray;
    $db->free($result);
Linking Dolibarr objects from two different modules
The key here is to use the llx_element_element: this is a standard Dolibarr table that stores all links between objects of two different modules.
Here is the structure:
rowid | fk_source | sourcetype | fk_target | targettype
1 | 2 | fichinter | 5 | facture
// Save the intervention's id
$fromobject = object(); // Init the object
