Module OVH (SMS, ClickToDial, ...)
Module name | |
Editor / Editeur | NLTechno (www.nltechno.com) - www.dolistore.com |
Prerequisites / Prérequis |
Dolibarr min version: 3.1.0 Dolibarr max version: {{{maxversion}}} |
Last update date / Date mise à jour fiche / Fecha última actualización | 2012-10-3 |
Note / Nota |
Add features to link Dolibarr between OVH web hosting services.
Then go on setup page, and add your OVH account:
* Nic handle * Mot de passe
For field "URL of SOAP OVH service", type the value provided as example.
* https://www.ovh.com/soapi/soapi-re-1.26.wsdl
Once information are input, you can click onto "Test connexion" to check that Dolibarr can communicate with OVH server.
- To send SMS, go on SMS tab and add name of SMS group to use (groups created from your online OVH manager). - To use ClickToDial, go on ClickToDial tab, take URL provided on page and paste it into ClickToDial module setup page, once module ClickToDial was activated.
SMS
- Go into card of a Thirdparty, Contact or Member. A new tab is visible to send SMS.
ClickToDial
- If the ClickToDial module (it's another module provided by default with all Dolibarr) was also activated, and URL provided by at previous chapter was filled into its setup page, a picto must be visible near to each phone number. Clicking on picto will launch phone numbering and launch your OVH phoning system.
Fetching invoices
See page Script importovhinvoice.php
