Module Pibarcode
Module name
Editor / Editeur NLTechno (www.nltechno.com) - www.dolistore.com
Last update date / Date mise à jour fiche / Fecha última actualización 2012-09-3
Add a new barcode generation engine. This engine use the PHP library Pibarocde (non free).
Go on Module Barcode setup page and choose "Pibarcode" as the engine to build barcode.
To complete
