Module Belgium EN
Revision as of 09:58, 3 September 2012 by Eldy (talk | contribs) (moved Module Belgium En to Module Belgium EN)
Module name | |
Editor / Editeur | Laurent Léonard - http://www.open-minds.org |
Prerequisites / Prérequis |
Dolibarr min version: 2.6 Dolibarr max version: {{{maxversion}}} |
Last update date / Date mise à jour fiche / Fecha última actualización | 2012-09-3 |
Note / Nota |
It allows you to generate and publish InterVAT documents.
Go into new menu entry "Belgium" to find all new features.
Development of this module is not included inside standard CVS repository of Dolibarr but into the private complementary modules area DoliForge. So source code is hosted into following source repository:
