Module Google
Revision as of 09:58, 3 September 2012 by Eldy (talk | contribs) (moved Module Google En to Module Google EN)
Module name
Editor / Editeur NLTechno (www.nltechno.com) - www.dolistore.com
Last update date / Date mise à jour fiche / Fecha última actualización 2012-09-3
Add into Dolibarr some Google integration:
  • Add into menu a new entry called "Google Agenda" to show contents of Google agendas.
  • Can add a Google Adsense tag into logon page.
  • Can add a Google Analytics tag into logon page.
From the application
Manually
unzip modulefile.zip
Setup of Agenda features
If you want to enable agenda feature, on Agenda tab, choose "Activate this tool".
Then for each Google agenda you want to show in menus, you must enter:
  • A label for this Agenda.
  • A color for this Agenda.
  • Google ID of Agenda. It can be found on the Google parameters pages for the agendas like this:
  1. Log to http://calendar.google.com
  2. Click on the "Parameters" link
  3. Click on the name of Agenda to show the Details of agenda.
  4. Search line "URL Address", you will see a text "Agenda ID : theagendaid@gmail.com"
200px
The Agenda ID is value that looks like an email. If you have only one Agenda, it might simply be your Google login.
Setup of Adsense
  • Your adsense customer id (ca-pub-xxxxxx)
Setup of Google analytics
  • Your Google analytics id (something like UA-xxxxxxx-y). You can find this id on Google analytics dashboard.
Choose menu Agenda Google, the agenda will be shown. If you have defined several agendas, you can limit view for only one of them using the left menu. The Google agenda is shown in read only mode. To add event into it, you must click on link "+ Google calendar" at bottom of agenda.
Google module add.jpg.
