Module MultiCompany
Revision as of 09:41, 3 September 2012 by Eldy (talk | contribs)
Module name
Editor / Editeur Regis Houssin - http://www.dolistore.com/
Last update date / Date mise à jour fiche / Fecha última actualización 2012-09-3
With this module, Dolibarr is able to manage several instances with only one installation (one unzipping and one database)
See Doliforge
