Module Labels
Revision as of 09:40, 3 September 2012 by Eldy (talk | contribs) (→‎Install)
Module name
Editor / Editeur 2byte.es (www.2byte.es)
Dolibarr min version: 3.1.0    Dolibarr max version: {{{maxversion}}}
Last update date / Date mise à jour fiche / Fecha última actualización 2012-09-3
Create labels printing for products in 70x36 and 70x37 format
