Module EsAEB
Module name | |
Editor / Editeur | 2byte.es (www.2byte.es) |
Prerequisites / Prérequis |
Dolibarr min version: 3.0.0 Dolibarr max version: {{{maxversion}}} |
Last update date / Date mise à jour fiche / Fecha última actualización | 2012-09-3 |
Note / Nota |
Create withdrawals files in the formats established by the Spanish AEB. Today generates the file under Rule 19.
What is AEB?
The Spanish Banking Association (AEB) is a professional association comprised of almost all Spanish and foreign banks operating in Spain. Among its tasks is the standardization of operational procedures to be used in banking relationships.
Once the module is installed and configured, you only have to create the standing orders and, if the configuration of the country of your company/foundation is Spain, it will create the withdrawals files according to Rule 19 of the Spanish AEB
