Module SkinEditor
Revision as of 09:33, 3 September 2012 by Eldy (talk | contribs)
Module name
Editor / Editeur NLTechno (www.nltechno.com) - www.dolistore.com
Dolibarr min version: 3.2.0    Dolibarr max version: {{{maxversion}}}
Last update date / Date mise à jour fiche / Fecha última actualización 2012-09-3
Allow to change the main color and font size of skin eldy. Setup can be done globaly for everybody, but each user can also personalize its color theme by himself.
Prerequisites
Use the eldy skin.
Specific setup page for module:
Into the setup page of module, fill:
  • The color code to define skin main color.
or
On tab "skin editor" into your user card, fill:
Once setup of module is done, Dolibarr use new colors.
