Module Zip AutoFill France - Belgium - Switzerland
Revision as of 09:28, 3 September 2012 by Eldy (talk | contribs)
Module name
Editor / Editeur NLTechno (www.nltechno.com) - www.dolistore.com
Dolibarr min version: 3.2.0    Dolibarr max version: {{{maxversion}}}
Last update date / Date mise à jour fiche / Fecha última actualización 2012-09-3
Load into database all zip codes of France and Belgium. This allow autocompletion for all zip and/or towns input into dolibarr screens.
Just activate the module. If you find a couple zip/town not found, go into menu home - setup - dictionnary. You will find a dictionnary to add missing entry.
