Module Pibarcode
| Module name | |
| Editor / Editeur | NLTechno (www.nltechno.com) - www.dolistore.com |
Dolibarr min version: 3.0.0 Dolibarr max version: {{{maxversion}}} |
| Last update date / Date mise à jour fiche / Fecha última actualización | 2012-09-3 |
| Note / Nota |
Add a new barcode generation engine. This engine use the PHP library Pibarocde (non free).
Go on Module Barcode setup page and choose "Pibarcode" as the engine to build barcode.
To complete
