Module BitTorrent
Revision as of 09:17, 3 September 2012 by Eldy (talk | contribs) (→‎Install)
Module name
Editor / Editeur NLTechno (www.nltechno.com) - www.dolistore.com
Last update date / Date mise à jour fiche / Fecha última actualización 2012-09-3
Add into Dolibarr, the capability to be a Bit Torrent tracker. This means you are able to serve files to the world on the Bit Torrent network with no need of external web sites or tools.
To complete
