Module CustomFields Cases
// ... php code ...
function __constructor($db) {
// ... php code ...
$this->name = "crabe";
into:
// ... php code ...
// ... php code ...
$this->name = "customfields";
* \brief Show the customfields in a new page
* \param pdf PDF factory
* \param object Object invoice/propale/order/etc... (CustomFields simpler functions will automatically adapt)
* \param outputlangs Object lang for output
global $conf;
// Init and main vars
$pdf->SetY($pdf->GetY()+1);
// Printing the customfields
// Get translated label
return 1;
// Pied de page
$pdf->AliasNbPages();
// CustomFields
$pdf->AddPage();
$pagenb++;
Conditions categories
- static condition: choices are restrained on a condition that never changes (eg: only show third-parties that are suppliers, or lowercase all data on sql insertion, or check that a field is above a certain number, etc.).
- semi-dynamic condition: choices that are constrained on a static table but based on the value of another field/customfield.
- dynamic: everything is dynamic: choices are based on a subfield of a field of the current module, so that there's no material table and it's impossible to create a view (because you would need to create one view per id) (eg: show only the contacts attached to the third-party being accessed)
- timed condition: a condition that is based on time or recurrence (eg: at 5:00 AM delete old records, etc..)
Conditions solutions
Now that you know what kind of condition you want to set, you can choose one of the following solutions depending on your preferences and knowledge:
Static condition
- View: create a view on the table based on the condition, and then create a custom field constrained on this view (which is just like any table), eg: only show third-parties that are suppliers:
SELECT *
FROM llx_societe
WHERE fournisseur=1;
- Check
- Trigger
- SQL Transformations
- CustomFields's overload functions
Semi-dynamic condition
- View
- Check
- Trigger
- Overload functions
Dynamic condition
- Making your own module, which calls the CustomFields class
Timed condition
- SQL scheduled events
- Cron job
- CustomFields's Overload functions
Overloading functions
1,les 2 alpes,isère 2,chamrousse,isère 3,alpe d'huez,isère 4,vars,alpes du sud 5,risoul,alpes du sud etc...
In CustomFields's admin panel, we create two custom fields: 1-secteur: returns the list of all zones - type DropdownBox: enum('- Aucun','Alpes du Sud','export','Haute-Savoie','Isère', etc...) 2-station_a: returns the list of all ski resorts - type constraint on llx_k_station
$result=$db->query($sql);
if ($result) {
$i = 0;
$myarray = array();
while ($i < $num)
$i++;
$value = $myarray;
$db->free($result);
Linking Dolibarr objects from two different modules
The key here is to use the llx_element_element: this is a standard Dolibarr table that stores all links between objects of two different modules.
Here is the structure:
rowid | fk_source | sourcetype | fk_target | targettype ------------------------------------------------------- 1 | 2 | fichinter | 5 | facture
// Save the intervention's id
$fromobject = object(); // Init the object
