Module CustomFields Cases
Revision as of 23:36, 29 August 2012 by Lrq3000 (talk | contribs) (Added llx_element_element php code example)
// ... php code ...
  function __constructor($db) {
// ... php code ...
    $this->name = "crabe";
into:
// ... php code ...
// ... php code ...
    $this->name = "customfields";
 *   	\brief      Show the customfields in a new page
 *   	\param      pdf     		PDF factory
 * 		\param		object			Object invoice/propale/order/etc... (CustomFields simpler functions will automatically adapt)
 *      \param      outputlangs		Object lang for output
    global $conf;
    // Init and main vars
    $pdf->SetY($pdf->GetY()+1);
    // Printing the customfields
        // Get translated label
    return 1;
// Pied de page
$pdf->AliasNbPages();
// CustomFields
        $pdf->AddPage();
        $pagenb++;
Conditions can be categorized into 3 types:
  • static (view on only prospect)
  • semi-dynamic (static table but based on the value of another field/customfield, like manub/rossy)
  • dynamic (based on another subfield of a field of the current module, like mermoz)
Overloading functions
1,les 2 alpes,isère
2,chamrousse,isère
3,alpe d'huez,isère
4,vars,alpes du sud
5,risoul,alpes du sud
etc...
In CustomFields's admin panel, we create two custom fields: 1-secteur: returns the list of all zones - type DropdownBox: enum('- Aucun','Alpes du Sud','export','Haute-Savoie','Isère', etc...) 2-station_a: returns the list of all ski resorts - type constraint on llx_k_station
$result=$db->query($sql);
  if ($result) {
    $i = 0;
    $myarray = array();
    while ($i < $num)
      $i++;
    $value = $myarray;
    $db->free($result);
Linking Dolibarr objects from two different modules
The key here is to use the llx_element_element: this is a standard Dolibarr table that stores all links between objects of two different modules.
Here is the structure:
rowid | fk_source | sourcetype | fk_target | targettype
1 | 2 | fichinter | 5 | facture
$eltrow = $customfields->fetchAny('*', MAIN_DB_PREFIX.'element_element', 'fk_target='.$object->id);
// Save the intervention's id
$fromobject = object(); // Init the object
