Module CustomFields Cases
conditions 3 types: static (view on only prospect), semi-dynamic (static table but based on the value of another field/customfield, like manub/rossy), dynamic (based on another subfield of a field of the current module, like mermoz)
Overloading functions
1,les 2 alpes,isère 2,chamrousse,isère 3,alpe d'huez,isère 4,vars,alpes du sud 5,risoul,alpes du sud etc...
In CustomFields's admin panel, we create two custom fields: 1-secteur: returns the list of all zones - type DropdownBox: enum('- Aucun','Alpes du Sud','export','Haute-Savoie','Isère', etc...) 2-station_a: returns the list of all ski resorts - type constraint on llx_k_station
$result=$db->query($sql);
if ($result) {
$i = 0;
$myarray = array();
while ($i < $num)
$i++;
$value = $myarray;
$db->free($result);
