Module CustomFields
Revision as of 15:01, 29 August 2012 by Eldy (talk | contribs)
CustomFields
Numero/ID of module 8500
Developer doc. of module Module CustomFields Dev
Description
Understanding CustomFields
Technically speaking, this module is a simple wrapper for your sql database. It respects sql standards and manage them in a standard way.
This means that you can modify your sql database with another tool (eg: phpMyAdmin), and this module will then manage it automatically.
Features overview
- Natively support the modules: Invoices, Propales and Products/Services.
- Full multilanguage support:
  • multilanguage in the administration gui (french and english for now, but can be translated by anyone using langs files)
  • multilanguage user-defined custom fields labels
  • multilanguage custom fields values (eg: yes/no select box can be translated to any language, same for enum user defined values). You can even translate the values of your dropdown boxes or your constrained fields.
- Several natively supported fields types :
  • Textbox
  • Areabox
  • YesNoBox
  • TrueFalseBox
  • DropdownBox (your own options)
  • Date
  • DateTime
  • Integer
  • Float
  • Double
  • Constrained (link to other tables)
  • Other (custom type, defined by your own SQL command)
- Custom sql statements to create complex fields : these custom sql statements will be executed after the creation/edition of the custom field definition.
Enabling the module
Creating a custom field
  • Label: this option is disabled, because the label will automatically be the same as the Field Name, but you can translate it (set it) in language files (see the related chapter below).
  • Field Name: sql field name. Choose any name you want, it just has to be alphanumeric without any space (you can use underscore '_'). You can also use remote sql columns names if you set a constrained field to enable Smart Value Substitution for this field (see the related chapter).
  • Type: the type of the field. This is where you choose what kind of data your field will hold, and more importantly how it will be shown (eg: Textbox, DropdownBox, etc..). You can also choose Other and set your own sql type by entering it in the Other box just below.
  • Size, or for DropdownBox the Values: if you want to set a specific size, you can set it here. By default, the module will set the right size for most uses, but if you find that it's too limited, you set any value. Also, this is required if you set an DropdownBox type, and instead of setting the size you should here set the values that will be offered in the box (eg: "firstval","secondval","thirdval" WITH the quotes and commas).
  • Accept null values: if enabled, the field will accept empty values. Else if disabled, a value will be required, and if an empty value is entered, the last non empty value will be used instead.
  • Default value: you can set the default value when a field has not received any value by the user yet.
  • Constraint: you can link the field to another table in the database. The field will then offer as choices the records in the remote table.
  • Custom SQL Definition: this is used to add more sql commands to the sql definition of the field (such as comments, meta parameters or transformations).
  • Custom SQL Statement: any sql command can be entered here and will be issued only ONCE after the definition of the field (thus the commands won't be issued every time the field is shown, but only once when you create the field!). This is the same as using a third-party tool such as phpMyAdmin, and is just offered as a quick shortcut.
Note: in Custom SQL Statement, do NOT do a
SELECT *
, it will be rejected by the injection protection of Dolibarr - and anyway this is totally useless as the module won't show you the result of the request, you should better try sql commands like View, Procedure, Trigger, Check, etc..
Modifying a custom field
Deleting a custom field
Translation of a custom field's label
Testing your custom fields with the PDFTest module
Implementing in ODT templates
{cf_user_ref}
{cf_user_ref_raw}
{cf_user_ref} = rowid
etc...
This is enabled and this will show.
Else this will show up when disabled.
We need to use the raw value, because we need to have a 0/1 value for the conditional to work (or empty/non-empty, so this can also work for empty Textbox: if there's no text, you can avoid to show anything - this in fact works for any other sql datatypes).
Implementing in PDF templates
  • To load the custom fields:
dol_include_once(DOL_DOCUMENT_ROOT.'/customfields/lib/customfields_aux.lib.php');
  • To access the field's value:
Beautified formatting:
or for the raw value:
  • To access a product's line's value:
  • To print it with FPDF (the default PDF generation library):
  • And if you want to print the multilanguage label of this field :
$mylabel = $customfields->findLabel("cf_myfield", $outputlangs); // where $outputlangs is the language the PDF should be outputted to
Implementing in php code (dolibarr core modules or your own module)
  • $object: the object where the custom fields datas will be set
  • $fromobject: the object from which the custom fields will be fetched (this can be used to fetch custom fields from multiple modules into one $object)
  • $langs: language translation class, to localize your custom fields values
  • $prefix: prefix to add to help you organize and avoid overwriting custom fields (eg: you have two modules and want to store into one $object, with $prefix='invoice' the first will store inside $object->customfields->invoice->cf_myfield, and second='propal' will store inside $object->customfields->propal->cf_myfield).
  • $pdfformat: beautify the customfields values? (null = no beautify nor translation; false = beautify and translate; true = translation and pdf beautify with html entities encoding)
  • First, you necessarily have to instanciate the CustomFields class:
// Init and main vars //include_once(DOL_DOCUMENT_ROOT.'/customfields/class/customfields.class.php'); // OLD WAY
$customfields = new CustomFields($this->db, $currentmodule); // where $currentmodule is the current module, you can replace it by if you just want to use printing functions and fetchAny.
  • Secondly, you have the fetch the records (this will fetch ALL custom fields for ALL records):
  • Thirdly, you can now print all your records this way:
if (!is_null($records)) { // verify that we have at least one result foreach ($records as $record) { // in our list of records we walk each record foreach ($record as $label => $value) { // for each record, we extract the label and the value print $label.' has value: '.$value; // Simple printing, with no beautify nor multilingual support print $customfields->findLabel($customfields->varprefix.$label).' has value: '.$customfields->simpleprintField($label, $value); // Full printing method with multilingual and beautified printing of the values. Note: We need to add the varprefix for the label to be found. For printField, we need to provide the meta-informations of the current field to print the value from, depending on these meta-informations the function will choose the right presentation. } } }
  • Full final code:
$customfields = new CustomFields($this->db, $currentmodule); // where $currentmodule is the current module, you can replace it by if you just want to use printing functions and fetchAny. // Fetch all records $records = $customfields->fetchAll(); // Walk and print the records if (!is_null($records)) { // verify that we have at least one result foreach ($records as $record) { // in our list of records we walk each record foreach ($record as $label => $value) { // for each record, we extract the label and the value print $label.' has value: '.$value; // Simple printing, with no beautify nor multilingual support print $customfields->findLabel($customfields->varprefix.$label).' has value: '.$customfields->simpleprintField($label, $value); // Full printing method with multilingual and beautified printing of the values. Note: We need to add the varprefix for the label to be found. For printField, we need to provide the meta-informations of the current field to print the value from, depending on these meta-informations the function will choose the right presentation. } } }
  • If you want to fetch only one record:
Do's and don't to avoid slowdowns when implementing CustomFields
* In PDF templates, use customfields_fill_object_lines() only ONCE before the loop, else it will be very heavy on CPU and memory usage.
* Adding a lot of customfields or product lines won't really slow down CustomFields in any way (datasheet printing, editing field, PDF/ODT generation, etc..), thank's to caching.
* Try to avoid the number of constrained customfields: adding a lot of constrained customfields will, because CustomFields automatically lookup the remote tables for every constrained field, so that you can access any remote column in your PDF. There is a cache mechanism that tries to speed up the process, so for example if you have many different constrained customfields on the same remote table (eg: with different Smart Value Substitution prefixes), then the performance won't be tampered, but if every constrained customfields is linked to a different table, there is no way around, it will slow down. If you encounter problems, try to limit the number of constrained fields you create, or try to add SQL indexes on the remote table of the constrained field, or don't use customfields_fill_object*() functions but directly access _only_ the fields you need by using the CustomFields class or your own sql query.
* Smart value substitution for constrained fields does not hamper any performance (eg: prefix of the remote column for auto replacement of the raw value by the specified column's value).
* Try to use customfields_fill_object() and customfields_fill_object_lines() only once per script, these functions are really heavy and do all the work for you, they are optimized and cache everything they can, but the drawback is that they're heavy. An easy way is to modify directly the original $object, so that the result will be transmitted to every other parts of Dolibarr (but be careful, do it only if you know that this will not conflict). You can also choose to not use these functions at all, and use directly the CustomFields class, if you have really specific needs, you can have fastest results (eg: if you don't need to fetch all the customfields but only one or a few, or if you only need the raw values).
Constraints
Adding a constrained/linked custom field
If you want your constrained field to show another value than the rowid, just set your custom field's name to the name of the remote field you want to show. Eg: let's say you want to show the name of the users in the llx_users table, not the rowid. Just create a table with the "name" and it will automatically show the name fields instead of the rowid. And don't forget, in the PDF and ODT, you can access all the remote fields, not only name, but firstname, phone number, email, etc..
Also, you can specify to use not just one remote field but several, by concatenating the name of all the remote fields you want to show separated by underscores. eg: name_firstname_login will show values formatted like 'Admin John admin'. Every value is separated by a space.
This can be particularly powerful if you want to show a list of choice with sublists. eg: let's say that llx_country_regions contains a list of countries and regions, like country region France Paris France Seine-Saint-Denis Canada Quebec
Advanced configuration
Changing the default variable prefix for fields name
This behaviour can easily be changed by editing the $varprefix value in /htdocs/customfields/class/customfields.class.php (it's at the beginning of the file, just after "class CustomFields").
Overloading functions: Adding your own management code for custom fields
The module offers an overloading facility where you can overload (read replace) functions of CustomFields by your own.
This can be used in various ways: to change how a particular field is printed, how a particular field is saved, to add your own SQL request to manage a custom field, etc.
To overload CustomFields's functions, edit the following file: /customfields/fields/customfields_fields_extend.lib.php
You will find inside all the informations you need, here is an excerpt:
/* Decription: you can overload a few functions of CustomFields to do your own stuff, mainly the printing and the management of the fields.
 * Guidelines:
 * global $db;
 * $myvar = GETPOST('myvar');
 * Usage:
 * save: at edition (on datasheet), you can change the values that will be stored in the database, and then CF will commit them (you don't have to, just change the values).
 * savefull: at edition (on datasheet), CF stops the processing and you do the rest of the commit to the database (WARNING: CF will not store the data, you have to do it!)
 * Format:
    global $db;
    $myarray = array(
          array(0, ''),
          array(1, 'test1'),
          array(2, 'test2'),
          array(3, 'test3'),
          array(4, 'test4'),
    print $myarray[$value][1];
    $myarray = array(
          array('id'=>0, 'value'=>''),
Adding a new sql data type
1/ Add the sql data type support in config Why: to show this data type as a choice in the admin page.
Edit the $sql_datatypes to add your own type : the key being the sql data type definition (must be sql valid), the value being the name that will be shown to the user (you can choose whatever you want). Eg:
2/ Manage the new data type (implement the html input field) Why: CustomFields must know how to manage this particular datatype you've just added.
As a guide, you should probably take a look below the comment
// Normal non-constrained fields
first, these are the simplest data types (above it concerns only constrained fields which is more dynamic and more complicated).
Here we will implement a printing function that will best represent the data type when not editing, just viewing the data in the datasheet
4/ Optional: translate the name of the data type and the values Why: CustomFields fully supports multilanguage, so you can easily translate or put a longer description with the langs files.
Troubleshooting
Q: I'm trying to edit a constrained customfield parameters in the admin configuration page, but everytime I change the constraint it goes back to None ?
A: This is behaviour is probably due to some of your records containing an illegal value for the new constraint. For example, if you switch your customfield's constraint from your products' table containing 100 products to your you choose the llx_users table containing 2 users, the database won't know what to do with the illegal values higher than 2, so it won't accept the new constraint and set to None. In this case, just edit yourself the illegal values, either by fixing them or just deleting all the values for this customfields (but in this case you can just delete the customfields and recreate it).
Q: I'm trying to delete a constrained customfield in the admin configuration page, but it doesn't work!
