Module CustomFields
Revision as of 02:40, 29 August 2012 by Lrq3000 (talk | contribs)
{{{name}}}
Numero/ID of module 8500
Description
Understanding CustomFields
Technically speaking, this module is a simple wrapper for your sql database. It respects sql standards and manage them in a standard way.
This means that you can modify your sql database with another tool (eg: phpMyAdmin), and this module will then manage it automatically.
Features overview
- Natively support the modules: Invoices, Propales and Products/Services.
- Full multilanguage support:
  • multilanguage in the administration gui (french and english for now, but can be translated by anyone using langs files)
  • multilanguage user-defined custom fields labels
  • multilanguage custom fields values (eg: yes/no select box can be translated to any language, same for enum user defined values). You can even translate the values of your dropdown boxes or your constrained fields.
- Several natively supported fields types :
  • Textbox
  • Areabox
  • YesNoBox
  • TrueFalseBox
  • DropdownBox (your own options)
  • Date
  • DateTime
  • Integer
  • Float
  • Double
  • Constrained (link to other tables)
  • Other (custom type, defined by your own SQL command)
- Custom sql statements to create complex fields : these custom sql statements will be executed after the creation/edition of the custom field definition.
Enabling the module
Creating a custom field
  • Label: this option is disabled, because the label will automatically be the same as the Field Name, but you can translate it (set it) in language files (see the related chapter below).
  • Field Name: sql field name. Choose any name you want, it just has to be alphanumeric without any space (you can use underscore '_'). You can also use remote sql columns names if you set a constrained field to enable Smart Value Substitution for this field (see the related chapter).
  • Type: the type of the field. This is where you choose what kind of data your field will hold, and more importantly how it will be shown (eg: Textbox, DropdownBox, etc..). You can also choose Other and set your own sql type by entering it in the Other box just below.
  • Size, or for DropdownBox the Values: if you want to set a specific size, you can set it here. By default, the module will set the right size for most uses, but if you find that it's too limited, you set any value. Also, this is required if you set an DropdownBox type, and instead of setting the size you should here set the values that will be offered in the box (eg: "firstval","secondval","thirdval" WITH the quotes and commas).
  • Accept null values: if enabled, the field will accept empty values. Else if disabled, a value will be required, and if an empty value is entered, the last non empty value will be used instead.
  • Default value: you can set the default value when a field has not received any value by the user yet.
  • Constraint: you can link the field to another table in the database. The field will then offer as choices the records in the remote table.
  • Custom SQL Definition: this is used to add more sql commands to the sql definition of the field (such as comments, meta parameters or transformations).
  • Custom SQL Statement: any sql command can be entered here and will be issued only ONCE after the definition of the field (thus the commands won't be issued every time the field is shown, but only once when you create the field!). This is the same as using a third-party tool such as phpMyAdmin, and is just offered as a quick shortcut.
Note: in Custom SQL Statement, do NOT do a
SELECT *
, it will be rejected by the injection protection of Dolibarr - and anyway this is totally useless as the module won't show you the result of the request, you should better try sql commands like View, Procedure, Trigger, Check, etc..
Modifying a custom field
Deleting a custom field
Translation of a custom field's label
Testing your custom fields with the PDFTest module
Implementing in ODT templates
{cf_user_ref}
{cf_user_ref_raw}
{cf_user_ref} = rowid
etc...
This is enabled and this will show.
Else this will show up when disabled.
We need to use the raw value, because we need to have a 0/1 value for the conditional to work (or empty/non-empty, so this can also work for empty Textbox: if there's no text, you can avoid to show anything - this in fact works for any other sql datatypes).
Implementing in PDF templates
  • To load the custom fields:
dol_include_once(DOL_DOCUMENT_ROOT.'/customfields/lib/customfields_aux.lib.php');
  • To access the field's value:
Beautified formatting:
or for the raw value:
  • To access a product's line's value:
  • To print it with FPDF (the default PDF generation library):
  • And if you want to print the multilanguage label of this field :
$mylabel = $customfields->findLabel("cf_myfield", $outputlangs); // where $outputlangs is the language the PDF should be outputted to
Implementing in php code (dolibarr core modules or your own module)
  • $object: the object where the custom fields datas will be set
  • $fromobject: the object from which the custom fields will be fetched (this can be used to fetch custom fields from multiple modules into one $object)
  • $langs: language translation class, to localize your custom fields values
  • $prefix: prefix to add to help you organize and avoid overwriting custom fields (eg: you have two modules and want to store into one $object, with $prefix='invoice' the first will store inside $object->customfields->invoice->cf_myfield, and second='propal' will store inside $object->customfields->propal->cf_myfield).
  • $pdfformat: beautify the customfields values? (null = no beautify nor translation; false = beautify and translate; true = translation and pdf beautify with html entities encoding)
  • First, you necessarily have to instanciate the CustomFields class:
// Init and main vars //include_once(DOL_DOCUMENT_ROOT.'/customfields/class/customfields.class.php'); // OLD WAY
$customfields = new CustomFields($this->db, $currentmodule); // where $currentmodule is the current module, you can replace it by if you just want to use printing functions and fetchAny.
  • Secondly, you have the fetch the records (this will fetch ALL custom fields for ALL records):
  • Thirdly, you can now print all your records this way:
if (!is_null($records)) { // verify that we have at least one result foreach ($records as $record) { // in our list of records we walk each record foreach ($record as $label => $value) { // for each record, we extract the label and the value print $label.' has value: '.$value; // Simple printing, with no beautify nor multilingual support print $customfields->findLabel($customfields->varprefix.$label).' has value: '.$customfields->simpleprintField($label, $value); // Full printing method with multilingual and beautified printing of the values. Note: We need to add the varprefix for the label to be found. For printField, we need to provide the meta-informations of the current field to print the value from, depending on these meta-informations the function will choose the right presentation. } } }
  • Full final code:
$customfields = new CustomFields($this->db, $currentmodule); // where $currentmodule is the current module, you can replace it by if you just want to use printing functions and fetchAny. // Fetch all records $records = $customfields->fetchAll(); // Walk and print the records if (!is_null($records)) { // verify that we have at least one result foreach ($records as $record) { // in our list of records we walk each record foreach ($record as $label => $value) { // for each record, we extract the label and the value print $label.' has value: '.$value; // Simple printing, with no beautify nor multilingual support print $customfields->findLabel($customfields->varprefix.$label).' has value: '.$customfields->simpleprintField($label, $value); // Full printing method with multilingual and beautified printing of the values. Note: We need to add the varprefix for the label to be found. For printField, we need to provide the meta-informations of the current field to print the value from, depending on these meta-informations the function will choose the right presentation. } } }
  • If you want to fetch only one record:
Do's and don't to avoid slowdowns when implementing CustomFields
* In PDF templates, use customfields_fill_object_lines() only ONCE before the loop, else it will be very heavy on CPU and memory usage.
* Adding a lot of customfields or product lines won't really slow down CustomFields in any way (datasheet printing, editing field, PDF/ODT generation, etc..), thank's to caching.
* Try to avoid the number of constrained customfields: adding a lot of constrained customfields will, because CustomFields automatically lookup the remote tables for every constrained field, so that you can access any remote column in your PDF. There is a cache mechanism that tries to speed up the process, so for example if you have many different constrained customfields on the same remote table (eg: with different Smart Value Substitution prefixes), then the performance won't be tampered, but if every constrained customfields is linked to a different table, there is no way around, it will slow down. If you encounter problems, try to limit the number of constrained fields you create, or try to add SQL indexes on the remote table of the constrained field, or don't use customfields_fill_object*() functions but directly access _only_ the fields you need by using the CustomFields class or your own sql query.
* Smart value substitution for constrained fields does not hamper any performance (eg: prefix of the remote column for auto replacement of the raw value by the specified column's value).
* Try to use customfields_fill_object() and customfields_fill_object_lines() only once per script, these functions are really heavy and do all the work for you, they are optimized and cache everything they can, but the drawback is that they're heavy. An easy way is to modify directly the original $object, so that the result will be transmitted to every other parts of Dolibarr (but be careful, do it only if you know that this will not conflict). You can also choose to not use these functions at all, and use directly the CustomFields class, if you have really specific needs, you can have fastest results (eg: if you don't need to fetch all the customfields but only one or a few, or if you only need the raw values).
Constraints
Adding a constrained/linked custom field
If you want your constrained field to show another value than the rowid, just set your custom field's name to the name of the remote field you want to show. Eg: let's say you want to show the name of the users in the llx_users table, not the rowid. Just create a table with the "name" and it will automatically show the name fields instead of the rowid. And don't forget, in the PDF and ODT, you can access all the remote fields, not only name, but firstname, phone number, email, etc..
Also, you can specify to use not just one remote field but several, by concatenating the name of all the remote fields you want to show separated by underscores. eg: name_firstname_login will show values formatted like 'Admin John admin'. Every value is separated by a space.
This can be particularly powerful if you want to show a list of choice with sublists. eg: let's say that llx_country_regions contains a list of countries and regions, like country region France Paris France Seine-Saint-Denis Canada Quebec
Advanced configuration
Changing the default variable prefix for fields name
This behaviour can easily be changed by editing the $varprefix value in /htdocs/customfields/class/customfields.class.php (it's at the beginning of the file, just after "class CustomFields").
Overloading functions: Adding your own management code for custom fields
The module offers an overloading facility where you can overload (read replace) functions of CustomFields by your own.
This can be used in various ways: to change how a particular field is printed, how a particular field is saved, to add your own SQL request to manage a custom field, etc.
To overload CustomFields's functions, edit the following file: /customfields/fields/customfields_fields_extend.lib.php
You will find inside all the informations you need, here is an excerpt:
/* Decription: you can overload a few functions of CustomFields to do your own stuff, mainly the printing and the management of the fields.
 * Guidelines:
 * global $db;
 * $myvar = GETPOST('myvar');
 * Usage:
 * save: at edition (on datasheet), you can change the values that will be stored in the database, and then CF will commit them (you don't have to, just change the values).
 * savefull: at edition (on datasheet), CF stops the processing and you do the rest of the commit to the database (WARNING: CF will not store the data, you have to do it!)
 * Format:
    global $db;
    $myarray = array(
          array(0, ''),
          array(1, 'test1'),
          array(2, 'test2'),
          array(3, 'test3'),
          array(4, 'test4'),
    print $myarray[$value][1];
    $myarray = array(
          array('id'=>0, 'value'=>''),
Adding a new sql data type
1/ Add the sql data type support in config Why: to show this data type as a choice in the admin page.
Edit the $sql_datatypes to add your own type : the key being the sql data type definition (must be sql valid), the value being the name that will be shown to the user (you can choose whatever you want). Eg:
2/ Manage the new data type (implement the html input field) Why: CustomFields must know how to manage this particular datatype you've just added.
As a guide, you should probably take a look below the comment
// Normal non-constrained fields
first, these are the simplest data types (above it concerns only constrained fields which is more dynamic and more complicated).
Here we will implement a printing function that will best represent the data type when not editing, just viewing the data in the datasheet
4/ Optional: translate the name of the data type and the values Why: CustomFields fully supports multilanguage, so you can easily translate or put a longer description with the langs files.
How to add the support of a new module
There are two cases: either the module already implements hooks, and you just have to configure CustomFields to support it, or either the module does not implements hooks nor triggers.
This chapter will guide you through the steps to make any module supported by CustomFields (be it a Dolibarr core module or your own module).
NEW WAY (simpler)
0/ Preliminary work You will need 3 things here: the module's table name, the module's context and the module's trigger action(s).
To get these informations, you can take a look inside the code of the module's files you want to implement:
or you can get it by printing it in the /htdocs/customfields/class/actions_customfields.class.php by adding print_r($parameters) and search for $parameters->context
  • module's trigger actions: search for "run_triggers(" or take a look at the wiki: http://wiki.dolibarr.org/index.php/Triggers#List_of_known_triggers_actions
  • module's table name: either find it by yourself in the database (looks like llx_themodulename) or by printing it in actions_customfields.class.php by adding print_r($parameters) and search for $parameters->table_element
1/ With these values, edit the config file (/htdocs/customfields/conf/conf_customfields.lib.php), particularly the $modulesarray and $triggersarray variables:
A- Add the context and module's table name in the modulesarray: $modulesarray = array("invoicecard"=>"facture",
                                           "propalcard"=>"propal",
                                           "productcard"=>"product",
                                           "ordercard"=>"commande",
"yourmodulecontext"=>"yourmoduletablename"); // Edit me to add the support of another module - NOTE: Lowercase only!
B- Add the triggers (there can be several triggers): $triggersarray = array("order_create"=>"commande", "yourmoduletriggeraction1"=>"yourmoduletablename", "yourmoduletriggeraction2"=>"yourmoduletablename");
Note: generally you will be looking to implement the _CREATE and _PREBUILDDOC actions.
Done, now the module should be fully supported! If that's not the case, try the following:
- If you can save and create but cannot generate the document, see the 4th step for implementing the PREBUILDDOC trigger. - If you can neither save nor create the fields, you just see them but changes are not committed when submitting, try to implement the support via the old way (which should work all the time for any case).
Developpers Notes
These notes are aimed to developpers that want to extend the functionnalities of the module or want to use it for extreme cases. This is not meant to guide implementers on how to implement and configure the module (see the related chapter for that).
Principles
CustomFields is simply a wrapper for SQL databases.
The module is based on SQL to manage the fields and most of the stuff. It uses and understand standard SQL.
The main principle of CustomFields is:
  • one SQL field = one Dolibarr field
  • one SQL type = one way to show and edit the field in Dolibarr
Goals
This module was made to provide an easy way to manage custom sql fields, not only for users and implementers, but also for developpers to use in their own module:
  • by easily adding the support of custom fields for your own module by using this module;
  • by reusing custom fields from another module in your own module;
  • by managing sql fields in your own module by using the CustomFields class (which will take care of everything from printing, editing to PDF/ODT templating).
So this module is not only an auxiliary of other modules, but it can also be the core part of your own module by using it as your SQL query class for fields.
SQL structure
A CustomFields table needs to respect three parameters that never change:
  • table's name (format: llx_*dolibarrmodule*_customfields where *dolibarrmodule* = table_element in conf_customfields.lib.php)
  • first column: rowid, which is the primary key for each field
  • second column: fk_*dolibarrmodule* which is the foreign key that links every customfields record to the Dolibarr's module that is associated (invoice, order, etc...).
Apart from the table's name and the first two special columns, every other columns are just standard sql columns that you can freely create, edit or delete as you want, from the module's administration page or from a third-party SQL management tool (such as phpMyAdmin).
You can also create more complex sql fields: constraints, foreign keys, transformations, other sql types, etc...).
Then the module will try to manage the sql fields you manually created the best it can:
  • by printing appropriate input fields in the Dolibarr gui interface.
  • by providing the developper an easy access to these fields in php (eg: $customfields->cf_myfield or $object->customfields->cf_myfield) for any use, including PDF templates and ODT templates, or in any php script (so that you can use these fields in your own module).
SQL Indexes
The module automatically adds an index on the primary key and foreign key (first and second columns).
To further optimize the performances of your database, and particularly the customfields tables, you may want to manually add indexes based on usage.
Also, you may add indexes on remote tables used by constrained fields, which could optimize even more the performances since constrained fields have the worst performance drawback for CustomFields.
Architecture
Here is a full list of the CustomFields packaged files with a short description (for a more in-depth view just crawl the source files, they are full of comments):
Core files
files that are necessary for the CustomFields to work, they contains the core functions
/customfields/admin/customfields.php --- Administrator's configuration panel : this is where you create and manage the custom fields definitions /customfields/class/actions_customfields.class.php --- Hooks class : used to hook into Dolibarr core modules without altering any core file (can be used to hook into your own modules too) /customfields/class/customfields.class.php --- Core class : every database action is made here in this class. You can find some printing functions because they are very generic. /customfields/conf/conf_customfields.lib.php --- Configuration file : contains the main configurable variables to adapt CustomFields to your needs or to expand its support to other modules and more native sql types. /customfields/conf/conf_customfields_func.lib.php --- Auxiliary functions library to read and manage config variables /customfields/core/modules/modCustomFields.class.php --- Dolibarr's module definition file : this is a core file necessary for Dolibarr to recognize the module and to declare the hooks to Dolibarr (but it does not store anything else than meta-informations). /customfields/core/substitutions/functions_customfields.lib.php --- CustomFields substitution class for ODT generation : necessary to support customfields tags in ODT files /customfields/core/triggers/interface_50_modCustomFields_SaveFields.class.php --- Core triggers file : this is where the actions on records are managed. This is an interface between other modules and CustomFields management. This is where you must add the actions of other modules you'd want to support (generic customfields triggers actions are provided so you just have to basically do a copy/paste, see the related chapter). Also, if CustomFields are shown in the forms but cannot be modified nor saved, then probably this trigger file is not detected by Dolibarr (maybe you can try to lower the number 50 to raise the priority?). /customfields/fields/customfields_fields_extend.lib.php --- Overloading functions library with users functions /customfields/langs/code_CODE/customfields.lang --- Core language file : this is where you can translate the admin config panel (data types names, labels, descriptions, etc.) /customfields/langs/code_CODE/customfields-user.lang --- User defined language file : this is where you can store the labels and values of your custom fields (see the related chapter) /customfields/lib/customfields_aux.lib.php --- Simplifier library to easily use CustomFields class to populate an $object with custom fields datas (Facade design pattern) /customfields/lib/customfields_printforms.lib.php --- Core printing library for records : contains only printing functions, there's no really core functions but it permits to manage the printing of the custom fields records and their editing /customfields/sql/*.sql --- Unused (the tables are created directly via a function in the customfields.class.php)
PDFTest module
optional module to append a page listing all custom fields values on newly generated PDF documents. To be used to test if custom fields are working correctly before making one's own template.
/customfieldspdftest/class/actions_customfieldspdftest.class.php --- Main functions library and hooks class, to hook onto pdf generation. Contains the PDFTest functions. /customfieldspdftest/core/modules/modCustomFieldsPDFTest.class.php --- Module descriptor for Dolibarr
Troubleshooting
Q: I'm trying to edit a constrained customfield parameters in the admin configuration page, but everytime I change the constraint it goes back to None ?
A: This is behaviour is probably due to some of your records containing an illegal value for the new constraint. For example, if you switch your customfield's constraint from your products' table containing 100 products to your you choose the llx_users table containing 2 users, the database won't know what to do with the illegal values higher than 2, so it won't accept the new constraint and set to None. In this case, just edit yourself the illegal values, either by fixing them or just deleting all the values for this customfields (but in this case you can just delete the customfields and recreate it).
Q: I'm trying to delete a constrained customfield in the admin configuration page, but it doesn't work!
TO DO
To Do:
  • Add a confirmation when deleting a custom field (because user's datas are lost forever!).
Should do :
  • Checkbox (multiple checkboxes, one for each possible value) and multiselect (big select and can use SHIFT to multiselect) (store in XML file) (but impossible with constrained fields, can't store multiple foreign keys ids in one single sql field, but would work for other types like enum)
use fieldset, input checkbox and label for, eg:
   <fieldset><legend><label for="cf_productslist"> $langs->trans('cf_productslist')</label></legend>
   <input type="checkbox" name="cf_productslist_choice1" value="1" id="cf_productslist_choice1" /><label for="cf_productslist_choice1"> $langs->trans('cf_productslist_choice1')</label>
<input type="checkbox" name="cf_productslist_choice2" value="1" id="cf_productslist_choice2" /><label for="cf_productslist_choice2"> $langs->trans('cf_productslist_choice2')</label>
etc... </fieldset>
  • Refactor the trigger array: merge it with the modulesarray (along with a new way to specify which customfields trigger action a trigger should correspond, eg: 'linebill_insert'=>'customfields_create').
  • Add a javascript options values generator for the enum type (a hidden input that would be shown only when DropdownBox type is selected and that would permit to add options by clicking a plus button).
Known bugs :
  • in product and service modules, if you edit a field, the proposals and other fields below won't be shown, you need to refresh the page. This problem resides in Dolibarr I think (since we are simply using a hook).
Never/Maybe one day :
  • Add Upload field type (almost useless since we can attach files).
  • Add support for repeatable (predefined) invoices (the way it is currently managed makes it very difficult to manage this without making a big exception, adding specific functions in customfields modules that would not at all will be reusable anywhere else, when customfields has been designed to be as generic as possible to support any module and any version of dolibarr, because it's managed by a totally different table while it's still managed by the same module, CustomFields work with the paradigm: one module, one table).
  • AJAX? (but only optional, because else it won't work for mobile phones and tablets)
  • Extend meta-data storage using XML files?
  • Add an AJAX select box for constained values : when a constrained type is selected and a table is selected, a hidden select box would show up with the list of the fields of this table to choose the values that will be printed as the values for this customfield (eg: for table llx_users you could select the "nom" field and then it would automatically prepend "nom_" to the field's name).
  • A way to reorder the fields without deleting/recreating (add a third special column after fk_module, or in XML meta-data file?)
