Restores
This page describe how to restore a backup of Dolibarr (for example after formatting your hard disk). To know how to do a complete backup, see page Backup.
Prerequisites
For a complete restore on a clean environment, we suppose that you :
- Have a backup of your database (into a dump file, done with mysqldump tool for example with a MySQL database).
- Have a backup of your document files directory.
- You know a login of an admin user you used before, when old Dolibarr backup was done.
Reinstall Dolibarr software
If you have uninstalled Dolibarr or not yet installed because you are on a new server, you must install Dolibarr as if you want to use it with a new clean database.
Be carefull to choose the same database type than before (Mysql, PostgreSQL...).
You can install any Dolibarr distribution of your choice (Dolibarr, DoliWamp, DoliMamp, any other Linux distribution...), however it must be exactly the same version (vX.Y) than the one used to make the backup (if backup was done using Dolibarr 2.7 or more, the version might be included in the file name of the database backup).
Restore documents
On your new installed Dolibarr, go with an administrator user in the menu Home / System Tools / Restore.
Dolibarr will show you where your documents files must be stored. This directory must be empty (if not you can purge it). All you have to do then is to copy content of your saved directory of old documents files into this directory.
Restore the database
MySql
Copy the backup dump file into the same directory than the command mysql.
If your backup file was a compressed archive, unzipping the file before might be required: For example, a bzip archive backup named mysqldump_dolibarr_2.7.0_200812021800.sql.bz2 must be uncompressed to mysqldump_dolibarr_2.7.0_200812021800.sql (Launch bunzip myfile.bz2 under Linux, or use 7zip under Windows).
Choose the import method.
Dolibarr offers a command line to launch to restore the database. Click on "Show the full command". For example, you will have :
mysql mydatabase -h localhost -u databaseuser -pdatabasepass < mybackupfile.sql
Open a command line shell (DOS Command line with Windows). Go into the directory where command mysql and your backup file is stored. Launch the command provided previously.
Alternative: you can also use phpMyAdmin Import tab to restore your backup file (normally you don't have to check any particular option, but your backup file needs to disable foreign_key_checks, see below).
in any case, your sql backup file should disable foreign keys prior to restoring, else your backup won't be restorable because of foreign keys clashing!
Eg: Add FOREIGN_KEY_CHECKS in headers and footers:
-- SQL Dump
-- Server version: 5.5.8
SET FOREIGN_KEY_CHECKS=0;
/*!40101 SET NAMES utf8 */;
INSERT INTO ...
CREATE TABLE ...
INSERT INTO ...
SET FOREIGN_KEY_CHECKS=1;
PostgreSql
Use your restored Dolibarr
After command is finished, you can go on Dolibarr logon. Now you must use a login account that was existing when the backup was done.
