The documentation related to other tables is available on the page: Table SQL
La documentation relative aux autres tables est disponible sur la page: Table SQL
La documentación relativa a otras tablas se encuentra disponible en la página: Table SQL
Eine Dokumentation zu weiteren Tabellen ist auf dieser Seite verfügbar: Table SQL
与其他表相关的文档请参阅:Table SQL
Content/Contenu/Contenido
Contains tasks related to a project.
Contient des tâches liées à un projet.
Contiene las tareas relacionadas a un proyecto.
Structure
Table
Field | Type | Null | Key | Default | Extra | Description |
rowid | int(11) | NO | PRI | auto_increment | technical index | |
fk_projet | int(11) | NO | MUL | ID of proyect (llx_projet->rowid) | ||
fk_task_parent | int(11) | NO | 0 | ID of task (llx_c_actioncomm->id) | ||
datec | datetime | YES | NULL | creation date | ||
tms | timestamp | NO | Current date | Date of last modification. See page Field Tms. | ||
dateo | datetime | YES | NULL | date start task | ||
datee | datetime | YES | NULL | date end task | ||
datev | datetime | YES | NULL | date validation task | ||
label | varchar(255) | NO | task label | |||
description | text | YES | NULL | task description | ||
duration_effective | real | NO | 0 | duration of task | ||
progress | int(11) | YES | 0 | progress of task | ||
priority | int(11) | YES | 0 | task priority | ||
fk_user_creat | int(11) | YES | NULL | ID of creator user (llx_user->rowid) | ||
fk_user_modif | int(11) | YES | NULL | ID of modifier user (llx_user->rowid) | ||
fk_user_valid | int(11) | YES | NULL | ID of validator user (llx_user->rowid) | ||
fk_statut | smallint(6) | NO | 0 | status | ||
note_private | text | YES | NULL | comentary notes | ||
note_public | text | YES | NULL | public comentary notes | ||
rang | int(11) | YES | 0 | rang |
Keys
Key | Type | Fields |
PRIMARY | PRIMARY | rowid |
fk_projet_task_fk_projet | MULTIPLE | fk_projet |
idx_projet_task_fk_user_creat | MULTIPLE | fk_user_creat |
idx_projet_task_fk_user_valid | MULTIPLE | fk_user_valid |
