Table llx projet task
Revision as of 12:49, 10 August 2012 by Eldy (talk | contribs) (→‎Table)
Content/Contenu/Contenido
En verysmall.png Contains tasks related to a project.
Fr verysmall.png Contient des tâches liées à un projet.
Es verysmall.png Contiene las tareas relacionadas a un proyecto.
Structure
Table
rowid int(11) NO PRI auto_increment technical index
fk_projet int(11) NO MUL ID of proyect (llx_projet->rowid)
fk_task_parent int(11) NO 0 ID of task (llx_c_actioncomm->id)
datec datetime YES NULL creation date
tms timestamp NO Current date Date of last modification. See page Field Tms.
dateo datetime YES NULL date start task
datee datetime YES NULL date end task
datev datetime YES NULL date validation task
label varchar(255) NO task label
description text YES NULL task description
duration_effective real NO 0 duration of task
progress int(11) YES 0 progress of task
priority int(11) YES 0 task priority
fk_milestone int(11) YES 0 ID of milestone (llx_projet_milestone->rowid)
fk_user_creat int(11) YES NULL ID of creator user (llx_user->rowid)
fk_user_modif int(11) YES NULL ID of modifier user (llx_user->rowid)
fk_user_valid int(11) YES NULL ID of validator user (llx_user->rowid)
fk_statut smallint(6) NO 0 status
note_private text YES NULL comentary notes
note_public text YES NULL public comentary notes
rang int(11) YES 0 rang
Keys
Key Type Fields
PRIMARY PRIMARY rowid
fk_projet_task_fk_projet MULTIPLE fk_projet
idx_projet_task_fk_user_creat MULTIPLE fk_user_creat
idx_projet_task_fk_user_valid MULTIPLE fk_user_valid
