Table llx projet
Revision as of 12:48, 10 August 2012 by Eldy (talk | contribs) (→‎Table)
Content/Contenu/Contenido
En verysmall.png Contains the proyects.
Fr verysmall.png Contient des projets.
Es verysmall.png Contiene los proyectos.
Structure
Table
rowid int(11) NO PRI auto_increment technical index
fk_soc int(11) YES MUL NULL ID of society (llx_societe->rowid)
datec date YES NULL date creation project
tms timestamp NO Current date Date of last modification. See page Field Tms.
dateo date YES NULL date start project
datee date YES NULL date end project
ref varchar(30) YES UNI NULL project reference
entity int(11) NO UNI 1 multi company id
title varchar(255) YES NULL project title
fk_user_resp int(11) YES NULL ID of user responsable of project (llx_user->rowid)
fk_user_creat int(11) NO NULL ID of creator user (llx_user->rowid)
public int(11) NO is project public?
fk_statut smallint(6) NO 0 status
note_private text YES NULL private comentary notes
note_public text YES NULL public comentary notes
model_pdf varchar(50) YES NULL Model PDF to print
Keys
Key Type Fields
PRIMARY PRIMARY rowid
uk_projet_ref UNIQUE ref,entity
idx_projet_fk_soc MULTIPLE fk_soc
