Table llx adherent options
Revision as of 16:59, 9 August 2012 by Eldy (talk | contribs) (→‎Table)
Content/Contenu/Contenido
En verysmall.png Contains the optional attributes of members of the association module
Fr verysmall.png Contient les attributs optionnel des adhérents du module association
Es verysmall.png Contiene los atributos opcionales de los miembros del módulo miembros
Structure
Table
rowid int(11) NO PRI auto_increment technical index
tms timestamp NO Current date Date of last modification. See page Field Tms.
fk_member int(11) NO MUL ID of member (llx_adherent->rowid)
Keys
Key Type Fields
PRIMARY PRIMARY rowid
idx_adherent_options MULTIPLE fk_member
