Table llx contrat
The documentation related to other tables is available on the page: Table SQL
La documentation relative aux autres tables est disponible sur la page: Table SQL
La documentación relativa a otras tablas se encuentra disponible en la página: Table SQL
Eine Dokumentation zu weiteren Tabellen ist auf dieser Seite verfügbar: Table SQL
与其他表相关的文档请参阅:Table SQL
Content/Contenu/Contenido
Contains the contrats. The contrats details are in Table llx_contratdet
Contient des contrats, les détails du contrat sont dans la Table llx_contratdet
Contiene los contratos, los detalles de los contratos están en Table llx_contratdet
Structure
Table
| Field | Type | Null | Key | Default | Extra | Description |
| rowid | int(11) | NO | PRI | auto_increment | technical index | |
| ref | varchar(30) | YES | UNI | NULL | contrat reference | |
| entity | int(11) | NO | 1 | See page Field Multi company id. (llx_entity->rowid) | ||
| ref_ext | varchar(30) | NO | See page Field ref_ext. | |||
| tms | timestamp | NO | CURRENT_TIMESTAMP | last update date | ||
| date_c | datetime | YES | NULL | creation date | ||
| date_contract | datetime | YES | NULL | date of contract | ||
| statut | smallint(6) | YES | 0 | status of contract | ||
| mise_en_service | datetime | YES | NULL | date of contract activation | ||
| fin_validite | datetime | YES | NULL | date of end validation | ||
| date_cloture | datetime | YES | NULL | date of contract close | ||
| fk_soc | int(11) | NO | MUL | ID society (llx_societe->rowid) | ||
| fk_projet | int(11) | YES | NULL | ID of proyect (llx_projet->rowid) | ||
| fk_commercial_signature | int(11) | NO | obsolete | |||
| fk_commercial_suivi | int(11) | NO | obsolete | |||
| fk_user_author | int(11) | NO | MUL | 0 | ID creator user (llx_user->rowid) | |
| fk_user_mis_en_service | int(11) | YES | NULL | ID activator user (llx_user->rowid) | ||
| fk_user_cloture | int(11) | YES | NULL | ID closer user (llx_user->rowid) | ||
| note | text | YES | NULL | comentary | ||
| note_public | text | YES | NULL | public comentary | ||
| import_key | varchar(14) | YES | NULL | Code used to save the import id. See page Field Import key. |
Keys
| Key | Type | Fields |
| PRIMARY | PRIMARY | rowid |
| uk_contrat_ref | UNIQUE | ref,entity |
| idx_contrat_fk_soc | MULTIPLE | fk_soc |
| idx_contrat_fk_user_author | MULTIPLE | fk_user_author |
