Module ClickToDial En
| Asterisk | |
| Numero/ID of module | 58 |
| Developer doc. of module | Module ClickTodial (developer) |
This module allows you to trigger a phone call with a simple mouse click on a phone number in Dolibarr. Any SIP server with an URL interface for the ClickToCall can be used. There is also information for setup with Asterisk.
With Asterisk
This is how to fill the specific setup for Asterisk:
- Add Url
- Go on page Setup - Other and add constants
ASTERISK_HOST with IP of your asterisk server (ie: 127.0.0.1) ASTERISK_TYPE with managed protocol (ie: SIP/) ASTERISK_INDICATIF with prefix to add in phone number (ie: 0 or NONE) ASTERISK_PORT with port of Asterisk sever (ie: 5038)
- Create a new console user on your Asterisk server ( File /etc/asterisk/manager.conf )
[dolibarruser]
secret = dolibarrpass
deny=0.0.0.0/0.0.0.0
- Enter Asterisk informations on your Dolibarr user card, tab ClickToDial
ClickToDial Login : dolibarruser ClickToDial Password : dolibarrpass ClickToDial Id caller (phone) : your phone
With a SIP softare (Ekiga), Linux and Firefox
- First, be sure, a SIP software (like Ekiga) is installed and working correctly (you can phone using it).
- Then, login to Dolibarr, go into ClickToDial module setup page. Into URL field, type
sip:__PHONETO__@yoursipdomain
For example, when using freephonie, the SIP system of the french ISP Free, URL would be
- Now, setup firefox to launch ekiga when using sip url:
- Launch Firefox
- Type about:config in the address bar and press ‘Enter’
3) Accept the warning 4) Right click somewhere on the page and select New –> Boolean from the menu 5) Set the name to “network.protocol-handler.expose.sip” without the quotes 6) Set the value to “false” 7) Close the about:config window (or tab) 8) Go on a card with a phone number (a third party or contact page for example). Click on phone link. When prompted, select the path to the launch script to run your SIP software (With Ekiga, you can set here path of script provided with Dolibarr 3.3+: yourdolibarrpath/scripts/clicktodial/ekiga.sh). Your browser should launch your SIP software and dial the number provided into URI each tie you click on a phone number. That’s it!
Once setup is finished, all phone number in Dolibarr screens are now links you can click. If you do so, Dolibarr will call then page to send informations to Asterisk server to execute the phone call. The Asteriks server should do the rest.
