Module Zip AutoFill France - Belgium - Switzerland
Revision as of 08:46, 4 July 2012 by Eldy (talk | contribs) (Created page with "Category:Complementary modules Category:ZiAutoFill {{TemplateDocDev}} {{TemplateDocUtil}} = Informations = {{TemplateModuleInfo |editor=NLTechno ([http://www.nltechno.com...")
Module name
Dolibarr min version: 3.2.0    Dolibarr max version: {{{maxversion}}}
Last update date / Date mise à jour fiche / Fecha última actualización 2012-07-4
Load into database all zip codes of France and Belgium. This allow autocompletion for all zip and/or towns input into dolibarr screens.
From the application
Manually
unzip modulefile.zip
Just activate the module. If you find a couple zip/town not found, go into menu home - setup - dictionnary. You will find a dictionnary to add missing entry.
