Module Labels
Revision as of 10:44, 29 June 2012 by Simnandez (talk | contribs)
Module name
Editor / Editeur 2byte.es (www.2byte.es)
Dolibarr min version: 3.1.0    Dolibarr max version: {{{maxversion}}}
Last update date / Date mise à jour fiche / Fecha última actualización 2012-06-29
Create labels printing for products in 70x36 and 70x37 format
From the application
Manually
unzip modulefile.zip
