Module Labels
Revision as of 10:42, 29 June 2012 by Simnandez (talk | contribs) (Created page with "Category:Complementary modules Category:Standing Orders {{TemplateDocDevEn}} {{TemplateDocUser}} = Informations = {{TemplateModuleInfo |editor=2byte.es ([http://www.2byte...")
Module name
Editor / Editeur 2byte.es (www.2byte.es)
Prerequisites / Prérequis Dolibarr min version 3.1.0
Last update date / Date mise à jour fiche / Fecha última actualización 2012-06-29
Create labels printing for products in 70x36 and 70x37 format
From the application
Manually
unzip modulefile.zip
