Module Interventions (developer)
Revision as of 15:58, 1 June 2012 by Simnandez (talk | contribs)
Interventions
Numero/ID of module 70
User doc. of module Module Interventions
Feature
This module allows you to manage interventions. You can define some interventions cards that contains one or several intervention lines defined by a comment, a date and a duration. It's goal is principally to follow such activities. In a future version, you should be able to transform interventions cards into invoices.
Entity Intervention
The PHP class to use to manipulate such object is file htdocs/fichinter/class/fichinter.class.php.
Entity Intervention line
Permissions
  • ->ficheinter->lire
  • ->ficheinter->creer
  • ->ficheinter->supprimer
  • ->ficheinter->export
Tables SQL
