Module Sales Orders
Orders | |
Numero/ID of module | 25 |
Developer doc. of module | Module Customers Orders (developer) |
With this module, you can manage (create, edit, delete), customers orders. You can also convert an order into an invoice (if Module Customers Invoices is used).
It provides also features to generate documents for each order in a format like PDF.
Suppliers orders are however manager by Module Suppliers Orders.
Note that activating this module will automatically activate the Module Third Parties.
Life cycle / Business rules
A customer order follow the following life cycle:
Draft --> Validated --> To bill --> Processed --> Canceled
Once an order is validated, by its creator, if you enabled the shipment module, you can generate one or several shipment receipts to send products. This can be done anywhen before the order is canceled or close with status processed.
You can also close treatment of an order (change status to "To bill") when you want (you decide if you do this before the shipment or after). With this status, you will be able to generate one or several invoices from customer order. The invoice will appears into menu "Orders to bill". If you click on "Billed", this switch status to "Processed" and order will disappear from menu "Orders to bill".
Create an order
Creation of an invoice need to go on card of a third party, on tab "Customer" (this require your third party has customer nature).
If Module Workflow En and Module Commercial Proposals enabled, you can also have a draft customer orders automatically created once a proposal is closed (You must set this into setup of Module Workflow En.
Modify an order
To modify an order, go on its card (you can find order from menu Commercial - Customers order - List or from Thirdparty card - Tab customer.
You can edit it if order has draft status. If not click on action button Modify.
Close an order
Once an order has been completely shipped, you can go onto card to close it.
If Module Invoice is activated, the order will be visible into list from menu Accountancy - To bill.
Delete an order
To delete an order, go on its card (you can find order from menu Commercial - Customers order - List or from Thirdparty card - Tab customer.
Then click on action button Delete order.
Warning, a deleted order is definitively removed with no way to restore it.
Examples of use cases
UCCU01: | |
Situation | |
Actions |
