Prerequisites
Dolibarr was build to work on following components :
OS
- Every OS are supported.
For example: Linux, BSD, Windows, MacOS, Aix, ...
Database
- Mysql 5.1+
If using option mode=STRICT returns some warnings or error, please report them to us.
- PostgresSql 9.1.0+
- MSSql (experimental support not working yet)
PHP
- Version 7.1.0+
- Support of user sessions must be enabled (it is the default value in all PHP)
- Works whatever is the parameter register_globals
- Works whatever is the parameter magick_quotes
- Works whatever is the parameter safe_mode
- PHP configuration must allow use of a max of 128Mb of memory (parameter PHP memory_limit).
