Translator documentation
<keywords content="translation, documentation, translator, localize, localization, i18n, internationalization" />
Language.png Translate Dolibarr into another language
Dolibarr languages files are translated in several languages. French and English are by default always complete. Other languages depends on contributions. This tutorial can help you to complete a translation that does not exists or is not correct for another language.
There are 4 methods for translating Dolibarr (1 automatic: autotranslator, 3 manual: phpLangEditor, iniTranslation and the completely manual method). They are in order of preference:
  • Translator OS: All
  • Tool: autotranslator.php provided with Dolibarr 2.5.1 and higher in directory dev/translation.
This method is recommanded when starting a translation for a language not already initialized. If there is already a translation available but you need to add missing key or correct errors, try to use next method.
php autotranslator.php lang_code_source lang_code_target
For example :
php autotranslator.php en_US pt_PT
All non existing files will be created, all existing files will be updated. The tool use Google translation service to find the translation value of a string, so a working Internet connection is required from station running the script. Because of limits of Google service, you may need to run the script secevral times to complete strings that fails. Script will automatically not translate strings already translated and submit only new lines. Your PHP must also have permissions to write into htdocs/langs directory and must have curl functions available.
Manual Translation with the Firefox plugin phpLangEditor
This is steps to follow to make a translation using the Firefox plugin
  1. Install Firefox and install plugin phpLangEditor (Media:PhpLangEditor254.xpi)
  2. A further step is required to complete the installation. Type into URL field, the text about:config then in the Filter field, enter phplangeditor. Double click on the line phpLangEditor.file.typeOfLangExt and put ini in field. phpLangEditor is now ready to translate Dolibarr.
  3. From Firefox, open phpLangEditor by selecting the menu Tools -> PHP lang editor.
  4. Click on "Open reference file" and choose your file. Lang original (eg in your Dolibarr, htdocs / lang / en_US / bills.lang
  5. Click 'Open file translation and select the file containing the translation, if a file exists (eg htdocs / lang / es_ES / bills.lang).
  6. You can choose to display all the words to translate the words or only non-translated. Click on the term in the left column to translate it into the box below. You can also use keyboard shortcuts such as CTRL + N to move to the next
  7. Save the file once the translation is finished.
  8. Edit the file with a text editor to remove or correct the first comment line. Indeed, with phpLangEditor, it is not possible to translate the lines Discussed (starting with #), the file contains translated once recorded the comment line of the source file. A small manual editing is needed to correct or delete this line, although this does not adversely affect the proper functioning of the new file. Lang.
Manual Translation with iniTranslator
  • Translator OS: Windows
  • Tool: iniTranslator (Windows).
This is steps to follow to make a translation using iniTranslator :
  1. Run your application translation will ask the template file (For example, under iniTranslator, do File - Open Original). Choose the source model in the directory htdocs / lang / en_US or htdocs / lang / en_US, which are up to date.
  2. Then choose the destination file may, in the directory htdocs / lang / xx_XX or xx is the language code to translate.
  3. Your tools will display the files 2 face to face with the missing strings to translate.
  4. Complete files.
  5. Save the new destination file.
Attention, iniTranslator has a serious defect. It does not retain the original order of the parameters and the generated file sorting alphabetically rather than keys in the order of the source file. In addition, areas comments source files are not reflected in the destination file translated.
Manual translation
To translate Dolibarr into another language, go to the langs directory and create a folder named with the code language to translate (Following the same format as those already existing, for example en_US, en_GB, es_ES, de_DE, etc.. ..). Then copy the files from a directory lang already translated (for example en_US / or main.lang en_GB / bills.lang), copy them into the directory of the new language that we have just created and bring the contents of these files.
These files are the following:
Code1 = translate phrases 1
Code2 = translate phrases 2
Coden = translate phrases n
Only sentences are = right to translate the code should remain unchanged. It is possible to translate the files one by one, without bringing them all at once. If a file has not been translated into the new language, Dolibarr use English.
To have a localise string into the PHP code, all you have to do then is loading the language file and use the method to get the translated value. This can be done like this:
print $langs->trans("CodeX")
And an entry type
CodeX = phrase X
must be added to the myfile.lang file.
Integrate its translation into Dolibarr
If you have completed existing but incomplete .lang files or if you have created new .lang files for a new language, you can:
  • You can upload changes/new files if you know how to use a GIT system. For this create an account on https://github.com/Dolibarr/dolibarr, fork Dolibarr project, make your change then send a Pull Request.
  • Or just send your files by mail attachment to the list: dolibarr-dev@nongnu.org. A developer will add it for you into project.
Note: There are 2 master languages, all 2 always complete:
  • English (Language files are into directory langs/en_US)
  • French (Language files are into directory langs/fr_FR)
You can use indifferently one or the other (which arrange) as a reference because the 2 are up to date. All other language files are likely to be incomplete.
Distribute your translation
Into official Dolibarr sources
The best thing after making a translation, is to include it on official version of Dolibarr. This is possible, if you know how to use a GIT system. For this create an account on https://github.com/Dolibarr/dolibarr, fork Dolibarr project, make your change then send a Pull Request.
As a separate addon file
When you create a new language, if it is not integrated into Dolibarr, it can still be spread to others. You can build a package to distribute using the script build/makepack-dolibarrlang.pl but you can also make a zip by your own to send it on dolistore.com or on developer mailing-list https://savannah.nongnu.org/mail/?group=dolibarr.
User just has to unzip package into its dolibarr root directory to have language available.
Language.png Translate documentation on wiki
The wiki is written in 3 languages: English, French and Spanish. If you want to enhance documentation on one of this language, all you have to do is to create an account on this wiki. Then, you can edit existing pages to correct a bad translation or translate pages waiting for translation on page Category:Page_waiting_for_translation.
