Table llx actioncomm
Revision as of 11:37, 10 February 2012 by Eldy (talk | contribs) (Undo revision 24603 by Eldy (talk))
Content/Contenu/Contenido
  Contains all the commercial actions (looks unused in many cases)
  Contient la liste des actions commerciales
  Contiene la lista de acciones comerciales
Structure
Table
id int(11) NO PRI auto_increment technical index
datec datetime YES NULL creation date
datep datetime YES NULL planned start date
datep2 datetime YES NULL deprecated
datea datetime YES MUL NULL real start date
datea2 datetime YES NULL deprecated
tms timestamp NO CURRENT_TIMESTAMP last update date
fk_action int(11) YES NULL ID of action (llx_c_actioncomm->id)
label varchar(50) NO label of action
fk_proyect int(11) YES NULL ID of proyect (llx_projet->rowid)
fk_soc int(11) YES MUL NULL ID of society (llx_societe->rowid)
fk_contact int(11) YES MUL NULL ID of contact (llx_socpeople->rowid)
fk_parent int(11) NO 0 ID of parent
fk_user_action int(11) YES NULL ID of user must perform the action (llx_user->rowid)
fk_user_done int(11) YES NULL ID of user who perform the action (llx_user->rowid)
fk_user_author int(11) YES NULL ID of user author of the action (llx_user->rowid)
fk_user_mod int(11) YES NULL ID of last user which modify the action (llx_user->rowid)
priority smallint(6) YES NULL priority of action
punctual smallint(6) NO 1
percent smallint(6) NO 0 percentage realised of action
location varchar(128) YES NULL
durationp real YES NULL planned duration
durationa real YES NULL deprecated
note text YES NULL comentary
propalrowid int(11) YES NULL ID of propal (llx_propal->rowid)
fk_commande int(11) YES NULL ID of order (llx_commande->rowid)
fk_facture int(11) YES MUL NULL ID of invoice (llx_facture->rowid)
Keys
Key Type Fields
PRIMARY PRIMARY id
idx_actioncomm_datea MULTIPLE datea
idx_actioncomm_fk_soc MULTIPLE fk_soc
idx_actioncomm_fk_contact MULTIPLE fk_contact
idx_actioncomm_fk_facture MULTIPLE fk_facture
