FAQ Migrate my Mysql database to PostgreSQL
Prerequisite
Your Dolibarr version must be at least version 3.2.0. If not, first upgrade your Dolibarr keeping MySql.
Process
Export Mysql
  • Go onto page Setup - Tools - Backup.
  • Choose export method "MySql dump".
  • Choose export compatibility "POSTGRESQL".
  • Uncheck Structure.
  • Check Name columns.
  • Choose No LOCK command around INSERT.
  • Choose "Compress None"
  • Then click on "Build backup".
  • Go into directory of your Dolibarr data files (directory is defined into "Setup - System information - Dolibarr - All parameters" on line "Root directory for data files").
  • Go into subdirectory admin/backup. You will find the dump of database you just build with previous step.
Create a PostGreSQL database
  • Ranme conf.php file of Dolibarr into conf.php.mysql (file should be into /etc/dolibarr or htdocs/conf)
  • Run Dolibarr. Because the conf file does not exists anymore, the install process will be suggested. Choose first installation and provide all informations of your postgresql database as data source. Run process until the end. About administrator account asked at end, choose same than the one exisitng into your MySql sessions.
Note: If you experience problem, you can go back to your Mysql database by restoring files renamed previsously.
Import dump file
  • Modify the generated file to set escape characters with correct characters:
sed -e "s/\\\'/\'\'/g" mysqldump_mydatabase_version_date.sql > tmpfile.sql
sed -e 's/\\/\\\\/g' tmpfile.sql > mysqldump_readyforpgsql.sql
  • Après avoir convertit le fichier, importer le sur votre base postgresql vierge:
psql -h name_or_ip_of_postgresql_server -d name_database_postgresql -U login_database_mysql -f mysqldump_readyforpgsql.sql
Modify your Dolibarr setup file
  • Open with a file editor, the file conf/conf.php that you can find into your Dolibarr root installation.
  • Modify lines make programs to point to new database
$dolibarr_main_db_host='name_or_ip_of_postgresql_server';
$dolibarr_main_db_port='port_server_postgresql';
$dolibarr_main_db_name='name_database_postgresql';
$dolibarr_main_db_user='login_database_mysql';
$dolibarr_main_db_pass='password_database_mysql';
Test
You should now have an application 100% working with all its data. Old MySql database can be closed.
