Create an ODT or ODS document template
This page describe how to build an ODT document template to build documents using ODT generation.
To know how to build a PDF template, see page Create a PDF document template. Building a PDF template require PHP development knowledge, but not building an ODT template.
Prerequisite
  • Dolibarr: 3.1+
  • OpenOffice: 3.2+, LibreOffice, ...
Create your document
  • Create from scratch an empty openoffice document and take a provided example. You may find them installed into a subdirectory of directory documents/doctemplates
  • Edit your document using all your Office suite features.
Include in your document the tags you want to see. Tags will be replaced during generation of document automatically by Dolibarr. List of all available tags are provided in next chapter.
Warning.png Warning, tags must be rounded with {} or [] for arrays (see later) and must be typed with no stop using Office suite (with no backward and no copy-paste). If not doing that, Office suite add some invisible informations making replacement not possible.
Tags
This is a list of tags that will be replaced with your informations:
Company/foundation information
mycompany_logo = {mycompany_logo}
mycompany_name = {mycompany_name}
mycompany_address = {mycompany_address}
mycompany_zip = {mycompany_zip}
mycompany_town = {mycompany_town}
mycompany_country = {mycompany_country}
mycompany_phone = {mycompany_phone}
mycompany_fax = {mycompany_fax}
mycompany_email = {mycompany_email}
mycompany_web = {mycompany_web}
mycompany_barcode = {mycompany_barcode}
mycompany_capital= {mycompany_capital}
mycompany_juridicalstatus= {mycompany_juridicalstatus}
mycompany_idprof1 = {mycompany_idprof1}
mycompany_idprof2 = {mycompany_idprof2}
mycompany_idprof3 = {mycompany_idprof3}
mycompany_idprof4 = {mycompany_idprof4}
mycompany_vatnumber = {mycompany_vatnumber}
mycompany_note = {mycompany_note}
Customers, prospects or suppliers information
company_name = {company_name}
company_address = {company_address}
company_zip = {company_zip}
company_town = {company_town}
company_country = {company_country}
company_phone = {company_phone}
company_fax = {company_fax}
company_email = {company_email}
company_web = {company_web}
company_barcode = {company_barcode}
company_customercode = {company_customercode}
company_suppliercode = {company_suppliercode}
company_capital = {company_capital}
company_juridicalstatus = {company_juridicalstatus}
company_idprof1 = {company_idprof1}
company_idprof2 = {company_idprof2}
company_idprof3 = {company_idprof3}
company_idprof4 = {company_idprof4}
company_vatnumber = {company_vatnumber}
company_note = {company_note}
User information
myuser_lastname = {myuser_lastname}
myuser_firstname = {myuser_firstname}
myuser_login = {myuser_login}
myuser_email = {myuser_email}
Object information (invoice, commercial proposal, order, ...)
object_id = {object_id}
object_ref = {object_ref}
object_ref_customer = {object_ref_customer}
object_ref_supplier = {object_ref_supplier}
object_date = {object_date}
object_date_creation = {object_date_creation}
object_date_validation = {object_date_validation}
object_total_ht = {object_total_ht}
object_total_vat = {object_total_vat}
object_total_ttc = {object_total_ttc}
object_vatrate = {object_vatrate}
object_note_private = {object_note_private}
object_note = {object_note}
Specific to proposals:
object_date_end = {object_date_end}    End date of validity of proposal
Lines of object
This is how to use arrays for lines of objects (invoices, commercial proposal, orders, etc...). You must create your array in the document and use a begin and end tag to define a line of the array. The line will then be repeated as much as required during generation.
[!-- BEGIN row.lines --]
[!-- END row.lines --]
Then, you can use following tags into your line:
	{line_fulldesc}
	{line_vatrate}
	{line_up}
	{line_qty}
	{line_discount_percent}
	{line_price_ht}
	{line_price_vat}
	{line_price_ttc}
This an example of what you may have in your office suite: Line for document generation.png
Other personalized tags
If you want to add a field that is not predefined, this is a solution:
  • Add a file into htdocs/includes/modules/substitutions/functions_mymodule.lib.php
  • Inside this file, just write one function like this:
/** 		Function called to complete substitution array (before generating on ODT, or a personalized email)
 * 		functions xxx_completesubstitutionarray are called by make_substitutions() if file
 * 		is inside directory htdocs/includes/modules/substitutions
 *		@param	array		$substitutionarray	Array with substitution key=>val
 *		@param	Translate	$langs			Output langs
 *		@param	Object		$object			Object to use to get values
 * 		@return	void					The entry parameter $substitutionarray is modified
function mymodule_completesubstitutionarray(&$substitutionarray,$langs,$object)
   global $conf,$db;
   $myvalue='Put here calculated value to insert';
   $substitutionarray['myowntag']=$myvalue;
Function will be called before generating document to complete the array used for substitution and to replace tag myowntag with value $myvalue. You can add as many tags as you need and put all personalized code you want to define values (search into database, into files, calculation, from received parameters or from global variables)...
Warning: First parameter in function parameter declaration must start with & as valu is modified by your code and must be returned modified. Moreover, function will be called only if module mymodule has been activated.
Store your document
To have your document to appear in list of available documents, put it into correct subdirectory found into directory documents/doctemplates
