Module OVH (SMS, ClickToDial, ...)
Revision as of 19:41, 3 February 2012 by Eldy (talk | contribs)
Module name
Dolibarr min version: 3.1.0    Dolibarr max version: {{{maxversion}}}
Last update date / Date mise à jour fiche / Fecha última actualización 2012-02-3
Add features to link Dolibarr between OVH web hosting services.
Depuis l'application
Manuellement
unzip fichiermodule.zip
Then go on setup page, and add your OVH account:
* Nic handle
* Mot de passe
For field "URL of SOAP OVH service", type the value provided as example.
* https://www.ovh.com/soapi/soapi-re-1.26.wsdl
Once information are input, you can click onto "Test connexion" to check that Dolibarr can communicate with OVH server.
- To send SMS, go on SMS tab and add name of SMS group to use (groups created from your online OVH manager). - To use ClickToDial, go on ClickToDial tab, take URL provided on page and paste it into ClickToDial module setup page, once module ClickToDial was activated.
SMS
  • Go into card of a Thirdparty, Contact or Member. A new tab is visible to send SMS.
ClickToDial
  • If you ClickToDial module was activated and URL as described at previous chapter was filled, a picto must be visible near to each phone number. Clicking on picto will launch phone numbering and launch your OVH phoning system.
Fetching invoices
See page Script importovhinvoice.php
