Script importovhinvoice.php
Revision as of 19:27, 3 February 2012 by Eldy (talk | contribs) (→Tables used/Tables utilisées/Tablas utilizadas)
Feature/Fonction/Funcionalidad
This script import PDF invoices provided by OVH into Dolibarr. If no corresponding supplier invoice are found into Dolibarr for each OVH invoice, the script ask to create it. Note that invoices are create with draft status so you can delete or validate them from Dolibarr.
Ce script importe les factures PDF fournies par OVH dans Dolibarr. Si aucune facture fournisseur dans Dolibarr n'est trouvé pour chaque facture OVH, le script demande si il faut la créer. Noter que les factures sont crées avec le statut "brouillon" ainsi vous pouvez les supprimer ou valider dans Dolibarr après l'import.
Syntax/Syntaxe/Sintaxis
php importovhinvoice.php dolibarrlogin nameforovhsupplier
- With value "dolibarrlogin" that is login to use to create invoices into Dolibarr.
- With value "nameforovhsupplier" that is name/ref of thirdparty into Dolibarr where to link created invoices to.
Localisation/Localización
- scripts/ovh/importovhinvoice.php
