Module Imports
| Imports | |
| Numero/ID of module | 250 |
| Developer doc. of module | This page |
To import data into Dolibarr, there is several solutions described here. This page describe solution using the import module. Other solutions to make mass imports are described in the page Mass imports.
See also page Setup Other, to modify the separator and charset of CSV import/export.
Examples of use cases
| UCMI01: | |
| Situation | I have an excel file with 3000 products. I want to import them into Dolibarr. |
| Actions | Go into menu Tools -> Import assistant -> New import |
| UCMI02: | |
| Situation | I have an text file with 1000 prospects. I want to import them into Dolibarr. |
