Script rebuild merge pdf.php
Feature/Fonction/Funcionalidad
This script is used to build one PDF that contains several PDF.
Ce script fabrique un fichier PDF à partir d'autres fichiers PDF.
Este script crea un fichero PDF a partir de otros ficheros PDF.
Localisation/Localización
- /dolibarr/htdocs/scripts/invoices/rebuild_merge_pdf.php
Syntax/Syntaxe/Sintaxis
To build/merge PDF for invoices with at least one payment in a date range:
Usage: rebuild_merge_pdf.php filter=payments dateafter datebefore [lang=langcode]
To build/merge PDF for invoices ina date range:
Usage: rebuild_merge_pdf.php filter=date dateafter datebefore [lang=langcode]
To build/merge PDF for all invoices, use filter=all
Usage: rebuild_merge_pdf.php filter=all
To build/merge PDF for invoices with no payments, use filter=nopayment
Usage: rebuild_merge_pdf.php filter=nopayment
To exclude credit notes, use
filter=nocreditnote
To exclude replacement invoices, use
filter=noreplacement
To exclude deposit invoices, use
filter=nodeposit
Example:
rebuild_merge_pdf.php filter=payments 20080101 20081231 lang=fr_FR
rebuild_merge_pdf.php filter=all lang=it_IT
