Module EMailing
Mailing | |
Numero/ID of module | 22 |
Developer doc. of module | Module EMailing (developer) |
Check also that Dolibarr setup to send mails is ok: Paramétrage_EMails
Mass E-Mailing features are available from menus (if Module EMailing has been activated). Menu link can be found in menu "Tools" with default menu manager "Eldy".
Life cycle / Business rules
The full process is this one:
- Then you choose the targets, among predefined dynamic lists from your Dolibarr data or from external files (For this, go on tab "Recipients" and click on button "Add" for predefined lists you want).
- You can modify this list, by removing targets for example.
- The mass e-mail sending is done then from screen or command line with script Script mailing-send.php. Only an emailing with status Validated can be sent by the script.
See page Script mailing-send.php for more information on how to launch it from command line.
